corner moldings
corner moldings
Postby Modstock » Sun Jan 13, 2013 10:53 am
Has anyone used corner moldings to hide electrical wires . Id need something slightly flexible to follow the shape inside.
The previous owners wiring doesent make sence to me so the wiring wont be inside the roof. Just wiring up about 4 lights (two reading lights and 2 other lights).
I'll be cutting off the previous owners wiring and stuffing it back into the roof.
Modstock
Re: corner moldings
Postby pete42 » Sun Jan 13, 2013 3:37 pm
I don't know what your building but this has been ask before and the answer is yes
some use factory moldings others have made their own using shaped wood and paneling100648 like this.
pete
pete42
Re: corner moldings
Postby Roly Nelson » Mon Jan 14, 2013 11:58 pm
Good idea, that is where I ran most of my wiring. I routed wire-races on the back side of the molding, which was part of the structural corners within the tear. Only problem I had, was when I shot a staple into the low voltage wire when I put the roof plywood on. Oh well, I over came it, probably just like you are about to do. Good luck.
8) ;) Roly ~~
Roly Nelson
L'il Ol' Woody Builder
