Edited to add, found a similar light at R&P Carriages for less. $19.95. http://www.ebay.com/itm/USA-MADE-TecNiq-Red-HI-Mount-Center-Brake-Turn-ID-Bar-11-LED-Light-Trailer-Truck-/290963377869?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item43bec4cecdMulti Function Rear Super bright 3 light Identification bar, That also functions as a high mount brake light. Lights up with turn signals and brake lights, Fully sealed.
Get one light that does it all! Add a extra measure of safety to any trailer!
With your headlights on, this unit acts as a normal 3 light bar.
Step on the brakes, and EIGHT SUPER BRIGHT LED's light up (between the 3 light bar) and let people know you are stopping!
And, when you are turning, 4 LED's each side blink with your turn signals, letting everyone know you plan to turn!
Dimensions:15.50" L x 1.60" W x .80" D
DOT/SAE approved
11 LEDs in each light bar
Functions as 3 light ID Bar, 3rd brake light and left/right turn signal.
Shock and vibration proof
Submersible & weatherproof
Sonically Sealed polycarbonate lens and housing
Available in two styles:
Red LEDs with red lens
Red LEDs with clear lens
Space / Channel saver design
4 wire pigtail (tail lights, ground, left turn, right turn)
Surface mount
MADE IN USA
Red lens
$26.95 each
53-4400
