heat
heat
Postby Greg Barrick » Sun Mar 03, 2013 1:12 pm
Hi Ya'll,
Just wondering, as I'm trying to work on my TD @ 25 degrees. I'm planning to have my TD "campable" by the 3rd week of May for a 2 week trip out west. (North) I was given a pick-up camper for parts. (2-3 yrs old pop up type) I was wondering, IF I used the water pump, the hotwater heater and an old heater core & fan, could I make a hot water furnace for the TD??? Could it be safe and efficient??? A decent boondock heater?
Greg Barrick
Re: heat
Postby Vedette » Sun Mar 03, 2013 1:36 pm
Hi Greg
Do you really think you need to go to that much work?
Teardrops are quite warm.......a small (cheap) ceramic heater would probably meet your needs. :thinking:
Good Roads
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: heat
Postby S. Heisley » Sun Mar 03, 2013 1:43 pm
Vedette wrote:Hi Greg
Good Roads
Brian
That's kind of my thoughts: ..."Why?" If you have insulation in your camper and a good sleeping blanket on top of your bed, you should be good to go for most trips. A small portable heater should be all you need. Just heating a kettle of water on the stove to a whistle heats my camper up 10 degrees in that amount of time and I have the high ceiling space on mine.
Re: heat
Postby Shadow Catcher » Sun Mar 03, 2013 1:51 pm
Yes it will work but you have to find a pump that will handle the heat. If you do a search for hot water circulator pumps you will find a number of them including 12V DC. You might be able to set temperature using a DC to DC buck converter to vary flow rate on the pump hence the heat.
But as pointed out if you have power a small heater will work very well.
Re: heat
Postby Greg Barrick » Sun Mar 03, 2013 3:37 pm
Thank you all. I was just wondering, 'cause I love to tinker (ol' retired engineer) and I've read alot about people trying to heat their TD with all kinds of options. Plus, like I said, ol' whats her name & I are hoping to have this thing campable by 3rd week of May for Montana, Wyoming, Colorado etc. I expect cool and some snow.
Greg Barrick
Re: heat
Postby Shadow Catcher » Sun Mar 03, 2013 5:34 pm
I have thought about it and since we have a 6 gal DSI water heater it would only take a bit of plumbing. Heater core with a computer case fan, I would recommend a three speed Antec 12V water pump controlled by a DC DC variable speed buck converter. Default temp on our water heater is 160. I have no idea what propane consumption would be but the small pumps are about 1A max.
If it were me I would probably use quick disconnects and insulated hoses.
