Lift Kits
Lift Kits
Postby garynparker » Sat Mar 09, 2013 7:27 pm
Are the use of lifts common on TTT's ? Let's say for storing a spare tire under or getting the trailer higher off the ground which makes it easier to get in and out. Any pro's and con's. Gary
garynparker
Re: Lift Kits
Postby Shadow Catcher » Sat Mar 09, 2013 9:28 pm
I am working on using air shocks to get some height when I need it.
Should have a usable system by summer. The disadvantage of a lift is that I may well lead to a less aerodynamic situation and higher center of gravity
57688
92895
83775
83777
83776
83778
Re: Lift Kits
Postby Woodbutcher » Sat Mar 09, 2013 10:52 pm
Using 15" tires will give you a good start. You could also use a Flexride torsion axle. They have adjustability in the torsion arms. But how high are you trying to get the deck from the ground ?
Woodbutcher
