Gray Water??
Gray Water??
Postby spbiknut » Wed Mar 20, 2013 9:41 am
So I'm wonder if I need a "Gray" water tank? I'm going to have a a 10 gallon fresh water tank for cleaning dishes and tanking a quick backwoods bath, but if I'm using earth friendly soaps do I really need the gray water tank? Just wondering what everyone else is doing? Most of my camping will be done down in the Florida Keys at RV parks so I will have access to showers and cleaning station for dishes, but there will be times when I'm off the beaten path. Thanks for any input you can send my way.
-Troy
"Tryin' to reason with hurricane season"
http://www.tnttt.com/viewtopic.php?f=50&t=54668
spbiknut
Images: 140
Re: Gray Water??
Postby kirkman » Wed Mar 20, 2013 12:01 pm
5 gallon buck :thumbsup:
kirkman
Images: 55
Re: Gray Water??
Postby pete42 » Wed Mar 20, 2013 2:40 pm
I have been in some parks where dumping grey water is prohibited others allow it to be dumped on campfires.
when I had a pop-up I used a plastic kitty-litter bucket that had a lid. I cut a hose size hole in the top stuck
the sink drain hose in and dumped it at the dump station. I have never camped very far off the beaten path
I think those folks have their own way of disposing of the water.
pete42
Re: Gray Water??
Postby Shadow Catcher » Wed Mar 20, 2013 5:48 pm
As indicated some parks require gray water capture and proper disposal and this can include shower drain water. Ours has a 16 gal RV type tank with a 3" RV gate valve. I was not happy with the bayonet type stinky slinky fittings and replaced it with camlock fittings. I just made an adapter from the 3" camlock to 3/4 hose and this will make it possible to use one of the five gallon flexible water containers to dump with out moving the trailer.
Re: Gray Water??
Postby pappaw » Thu Mar 21, 2013 11:31 am
The soaps we have these days break down right away and are harmless, so if your out where you can, you can use a bucket and then just go water a tree with it when you dump it. But I would not pour it in a lake or stream, let the plants and soil finish it off for you.
My 2 cents
Image Cheers from Granny, Pappaw, and Cocoa (the Dachshund) Image
pappaw
Images: 14
Re: Gray Water??
Postby Shadow Catcher » Thu Mar 21, 2013 7:23 pm
Biodegradable soap is not all that biodegradable and should not be used with in 200 feet of a water source
"All soaps, unfortunately even biodegradable ones, can contaminate fresh water sources.
Using a biodegradable soap doesn't reduce its immediate environmental impact...
..it just means that the soap will biodegrade in time."
http://www.backcountryattitude.com/biod ... _soap.html
I have been aware of this for some time and careful how we dispose of gray water.
Re: Gray Water??
Postby wagondude » Thu Mar 21, 2013 7:32 pm
Campgrounds in the Black Hills area (like around Jewel Cave) all prohibit dumping of grey water. The soap can break down the mineral formations when it leaches into the caves.
Bill
101137
wagondude
Images: 35
Re: Gray Water??
Postby BrwBier » Sat Mar 23, 2013 4:02 pm
I have never seen an established campground that allowed dumping gray water on the ground. There might be some but I have never encountered one. If you choose to ignore the rules do not complain when some one chooses different rules than you.
Brwbier
BrwBier
Images: 100
Re: Gray Water??
Postby pappaw » Sun Mar 24, 2013 11:28 am
"I have never seen an established campground that allowed dumping gray water on the ground"
Neither have we, but who said anything about that anyway?
pappaw
Images: 14
