I have been reading online there is no way to get rid of it without removing the carpeting. These seems expensive and severe.
Martiangod wrote:Borax, $5 in the laundry isle
Clean everything down with Borax and water solution.
When it drys vacumm up the chalky residue and repeat. Wear a particle mask. Borax is the very best mould remediation there is. Ion generators are dangerouse and expensive. After several cleanings with Borax. You can go to the orange store and rent a fogger and use Concrobium in it, also if you have a marine supply around, get some Captain Phab mould spray, once everything is clean' seal with a good sealer.
Mould is the most dangerouse thing in an enclosed space, BUT it can be treated and safe. Soft goods such as mattress, if its not turning black, lay it out in the sun as much as possible, and ait out the unit as much as you can, maybe assist with exhaust fans
This comes from 30 years workin on RV's, NOT guess work
