HF bearing question
HF bearing question
Postby Melven » Thu May 02, 2013 2:21 pm
My tailer came with what looks like pre greased bearings. In the directions they make a big deal about greasing them. Do I need to clean this grease off and re grease them or are they fine?
Melven
Re: HF bearing question
Postby suckerpunched » Thu May 02, 2013 3:32 pm
clean them and use a good quality grease
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby Melven » Thu May 02, 2013 3:46 pm
suckerpunched wrote:clean them and use a good quality grease
What should I clean them with? There is a ton of grease in there.
Melven
Also would marine grease be ok?
Melven
Postby absolutsnwbrdr » Thu May 02, 2013 4:06 pm
That crap that comes in them is just a rust-inhibiting gel. Wipe all that stuff off bearings and hubs, and then spray everything clean with brake cleaner. Repack with a good bearing grease. I like Valvoline SynPower Full-Synthetic multipurpose grease
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Melven » Thu May 02, 2013 9:00 pm
absolutsnwbrdr wrote:That crap that comes in them is just a rust-inhibiting gel. Wipe all that stuff off bearings and hubs, and then spray everything clean with brake cleaner. Repack with a good bearing grease. I like Valvoline SynPower Full-Synthetic multipurpose grease
Solid advise. Thank you.
Melven
Postby LDK » Fri May 03, 2013 6:48 pm
Instead of using a multipurpose grease you would be better off using a grease designed just for wheel bearings. I just repacked my HF bearings and I used this.
I also bought extra bearings and seals too.
LDK
Postby marshall0000 » Sun May 05, 2013 2:02 am
Melven wrote:My tailer came with what looks like pre greased bearings. In the directions they make a big deal about greasing them. Do I need to clean this grease off and re grease them or are they fine?
Almost any grease will be fine including the stuff that they came packed with. Just be sure you keep grease in there. If you want to go overboard use Mystic JT-6 Hi temp. No need to overthink this.
marshall0000
Postby pete42 » Sun May 05, 2013 5:46 am
your concern about packing the bearings is legit
others have already said what they use I also used a grease designed for bearings.
I cleaned mine using kerosene and a stiff round brush some use gasoline but I found gas tends to cause rust.
what ever you use, keep them lubed and you won't go wrong.
pete42
Postby absolutsnwbrdr » Sun May 05, 2013 9:37 am
marshall0000 wrote: Almost any grease will be fine including the stuff that they came packed with.
:o :NC :frightened:
NO NO NO NO :?
The stuff that comes on Harbor Freights' bearings and hubs IS NOT BEARING GREASE.
You know how we know? Because it says so right in the manual.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby les45 » Sun May 05, 2013 10:43 am
I agree with the others that the stuff that comes with the trailer kits is not suitable grease. Also, you never know how much contaminants they may have left in the grease like dirt or metal shavings. I'm more concerned about how people clean the bearings (gasoline?). I only use acetone or brake cleaner and even then I use nitrile gloves and lots of ventilation anytime I'm cleaning or packing.
les45
Images: 605
Postby Wolffarmer » Sun May 05, 2013 11:29 am
I live dangerously, clean the bearings in gasoline and don't wear gloves. At least I don't smoke while doing it. ( I have seen people smoking while cleaning parts in gas ) That is something even I will not do. But yes nitrile gloves are not a bad idea. Keep the fumes down wind, DO NOT SMOKE. Next time I think about repacking bearings will probably use Coleman fuel. That is not half as nasty as car gas. Then a dip in kerosene as I have a lot of that around. Then keeping the bearings from spinning blow them out with compressed air. Don't forget to clean the race also. Then really squish the good quality grease into the bearings. I can't see that it matters if you use a grease marked for wheel bearings or some high quality grease. I use high quality stuff. Can't remember the name right now and I am to lazy to run out to the shop. But I think it is some Lubriplate product. It is kind of blueish, maybe next time I will stop at JOhn Deere and pick up some JD green grease. I pick it up at a bearing store here in town. I don't think I would even bother to look in Walmart for good grease. Unless you are going for that 50's greased hair look.
Randy
Wolffarmer
Images: 309
Postby eamarquardt » Sun May 05, 2013 2:41 pm
You can read Chinese? :lol: :thumbsup: :applause: :beer: :wine: :D
eamarquardt
Images: 150
Postby pjo129 » Sun May 05, 2013 3:00 pm
Thanks for the great advice. I had the same question.
Pete Olson
Newburgh, IN
pjo129
Images: 73
Postby markhusbands » Sun May 05, 2013 9:32 pm
I cleaned the bearings with gas and packed them with bearing grease from NAPA. I used a little syringe style gizmo to force the grease around the bearing. Did it work? No idea; thing's still parked in my garage.
133923
markhusbands
Images: 58
