Remodeling a 1947 Tourette Teardrop: Fuse Panel Placement
Postby burlesot » Sun May 05, 2013 7:07 pm
Hello.
I'm making good progress on my teardrop restoration/remodeling project. Here is the blog where all the details are: http://toddsteardropblog.blogspot.com/2013/05/galley-work.html
I am at the spot where I am about to begin putting in my electrical.
I have decided to put the battery in the galley, under the cabinet on the right side. I am planning to install a West Marine fuse panel with six inputs. It is a nice panel in that there are six lit power fuses. I am contemplating putting the fuse panel on the lower right cabinet door so that it is visible. I am also considering putting the fuse panel inside the cabinet. Obviously in this case, it would not be visible without opening the door.
105891105890
What advice would you give me on this decision?
Thank you,
Todd
burlesot
Images: 62
Re: Remodeling a 1947 Tourette Teardrop: Fuse Panel Placeme
Postby doug hodder » Sun May 05, 2013 7:37 pm
I'd hide it, just for a cleaner galley area. If a fuse is blown...you'll know it soon enough. If it's wired correctly, wires are protected and you don't overload a circuit they don't blow. I've never replaced a fuse in any of my tears once they are finished and out on the road. If you dig the look of a "control" panel, make it visible. Doug
Postby burlesot » Sun May 05, 2013 8:55 pm
Doug
Thanks for your thoughts
T
burlesot
Images: 62
Postby burlesot » Fri Jun 14, 2013 10:01 pm
Just an update.
108118108120
Bulkhead insulated and cedar installed; braced for the night.
Shelf area insulated and cedar installed; braced for the night.
Thanks,
Todd
burlesot
Images: 62
