Dale M. wrote:Ummm.... What tires and weight requires you to have 50 psi in your tires.... Seems a little high....
Dale
slowcowboy wrote: just get yourself a normal air comperssor and fill up at home!!!!!!!!!!!!!!
slowcowboy wrote:
I run 215/75/15 inch tires they are mudd and snow heavy lts for off road use.
they run 50 pounds of air easly! and they are on my teardrop.
Even if your tires can take 50 psi, doesn't mean they should. Tire pressure should be matched with the load. Too much pressure on a light load results in wearing out the middle of the tire, and a much harsher ride.
This is a chart I came across a few years back to help with many tire pressure/load combinations.
https://lh3.googleusercontent.com/-jyBi ... vs+psi.jpg
I checked the chart...my tires are "Load Range C"...what Load Index does that equate to on your chart? Also, there is no heading on the chart. Is this chart for A) Bias passenger tires...B) Radial passenger tires...C) Bias special trailer tires...D) Radial special trailer tires...E) Bias light truck tires...or F) Radial light truck tires? Without knowing what the chart is for it is hard to determine the likelyhood of the chart being useful for any given tire.
Jim, The load index on the left is on the side of the tire. It is useful in showing the relationship of tire pressure to the actual load rating because you can adjust your tire pressure to the weight of the trailer.
Fred
Dale M. wrote:About tire pressures.....
For Michelin
Compare the measured psi to the psi found on the sticker inside the driver’s door of your vehicle or in owner’s manual. DO NOT compare to the psi on your tire’s sidewall
Granted the above is about car manufacturers recommendation of tire pressures for a particular tire found on specific car model...
BUT this tells me you inflate tires by what ever application you are using tire for NOT THE MAXIMUM STATED ON TIRE SIDE WALL....
Dale
jstrubberg wrote:Jim;
I have to admit, my responses to this topic were based 100% on both recommendations for and personal use of passenger car and light truck tires.
I can't imagine how the tire industry can think that it's desirable for a passenger car tire sidewall to flex and a trailer tire sidewall not to flex, but you are correct, they absolutely do recommend running max pressure in trailer tires.
Folks, please, PLEASE recognize this is not the case with passenger car and light truck tires! No manufacturer, not one, recommends running max pressure in a car or truck tire unless you are at max load. Every car has a placard, usually on the drivers side door post, with recommended tire pressures. The number on the side of the tire is NOT the recommended pressure!
Jim, I'm sorry for derailing your thread. You were right, I was wrong. I saw what I wanted to see, not what you wrote.
