New to this
New to this
Postby nuyork212 » Sun May 19, 2013 10:37 pm
Hello All
My first question is how do you insure a homemade teardrop?
nuyork212
Re: New to this
Postby dreadcptflint » Sun May 19, 2013 11:43 pm
I'm not licensed in Colorado, however here is some general advice that should help. Anything unique is difficult for a carrier to insure. Seriously, if there is only one out there then it is difficult to determine value. Here are some methods.
1. If you are doing an inexpensive trailer then look at your home owner's policy. Some policy provide limited coverage to a trailer.
2. Recycle a frame and have the trailer register the frame. Use an old pop up or something similar.
3. A professional build frame with a registration number.
4. If the insurance company allows then insure it using a endorsement under a specified towing vehicle.
Despite mine being a limited run, I used three and four to get an inexpensive rate. If I was needing something more robust due to living in for long duration then I would spend a little more for a stand alone policy.Work with an Agent, we can do unusual things for example, I had a request the other week to insure a homemade pontoon boat.
dreadcptflint
Images: 19
Re: New to this
Postby Shadow Catcher » Mon May 20, 2013 5:25 am
How it was registered made no difference in how our insurance claim was handled. An adjuster came out and assessed that it would cost less to repair than replace, and part of that was that it could not have been replaced.
