Need Tips for Trailer Registration for WA /CA.
Postby IslandStorm62 » Thu May 23, 2013 2:37 pm
Hi All,
I am going to build my teardrop on a HF Super Capacity Trailer (1720 Lbs Capacity w/GVW 1980), so this would be classified as a Class 1 Trailer, less that 2000lbs (for Washington). I have not found California rules yet.
After my buildup, it should be less that 2000lbs and be a Class 1 trailer. Does the fact that it is built up as a camper make a difference?
Has anyone registered their homemade Teardrop in Washington or California? Any advice?
I am purchasing the trailer "package" here in Washington. My original plan is to transport the package to California and then build it.
However, I was wondering if I might eliminate some problems if I build the trailer here and get it registered before taking it down to California for the Teardrop build. Or does it even matter?
Bottom-line is that it will eventually need to be permanently registered here in Washington.
IslandStorm62
Re: Need Tips for Trailer Registration for WA /CA.
Postby eamarquardt » Thu May 23, 2013 4:46 pm
Here in California if it is a camping trailer they will register it as such and will charge you up the ying yang each year ($100/year for my Little Guy). If you register it as a utility trailer (don't have a cabin on it when you register it) they will register it as a utility trailer with PTI (Permanent Trailer somethingerother) for about $15 for five years. I doubt they'll ever notice that you now have a cabin on your utility trailer.
Choose wisely.
Gus
eamarquardt
Images: 150
Postby Dale M. » Thu May 23, 2013 8:54 pm
All the good news and bad news about CALIF. trailer registration can be found here...
http://www.dmv.ca.gov/pubs/vctop/vc/vc.htm
Takes a little digging... Might want to start under "T"..... And be careful about the weight, if you get too heavy it requires brakes in CA.....
Dale
Dale M.
Images: 18
Postby milliejohn » Thu May 23, 2013 10:12 pm
http://www.dmv.ca.gov/commercial/cvra.htm#pti
Not a big deal, I have 3 PTI trailers at this time, read the above link and stop at a DMV office if you need answers.
Image ~I started out with nothing and I still have most of it left~
milliejohn
Images: 87
