Maybe use some spacers so the lid would pivot like normal. Maybe put them on opposite sides so the lids would open outward to become small shelves. Anybody already think of this?
Junkboy999 wrote:Might look great on one of these Big off road teardrops. You don’t need 4, just 2. One on each side with the tool box area behind the wheel. All you need is some diamond plate that matches mounted under the half arch area and then bent to the appropriate angle to make the front part of the fender.
Junkboy999 wrote:Might look great on one of these Big off road teardrops. You don’t need 4, just 2. One on each side with the tool box area behind the wheel. All you need is some diamond plate that matches mounted under the half arch area and then bent to the appropriate angle to make the front part of the fender. I believe those are even made for left and right sides of truck beds. I like the ones with the shallow box on top and pull out draws facing backwards. Google images WHEEL WELL TOOLBOX
markhusbands wrote:How about you buy two of those and one diamond plate jeep fender of the appropriate size, saw the jeep fender in half, and bolt the halves to each wheel well box to finish off the full wheel well?
Users browsing this forum: Bing [Bot] and 9 guests
