Great deal on 12v / USB charging station
Postby danlott » Wed Jun 12, 2013 11:55 am
Found a great deal on 12v / USB charging stations on ebay. The outside trim piece is 3.75 x 5 inches, which is larger than I had pictured, but they are very nice.
http://www.ebay.com/itm/330873421798?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_554wt_1165
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Re: Great deal on 12v / USB charging station
Postby GerryS » Wed Jun 12, 2013 9:55 pm
danlott wrote:Found a great deal on 12v / USB charging stations on ebay. The outside trim piece is 3.75 x 5 inches, which is larger than I had pictured, but they are very nice.
Dan
I need something like that, with about 5 or 6 USBs...3 or4 phones, and 2 iPads. Man, I hate technology sometimes!
GerryS
Postby eamarquardt » Wed Jun 12, 2013 11:25 pm
eamarquardt
Images: 150
Postby Forrest747 » Fri Jun 14, 2013 8:05 am
http://www.bluesea.com/products/1016
I found this and wish I had found these a while back.
Forrest747
Cowbell Donating Member
Images: 447
Postby mgb4tim » Fri Jun 14, 2013 11:36 am
I'm no electrical engineer, but I've found that some of the smaller cigarette lighter USB adapters don't provide enough current to charge some items. It took a few until I found one powerful enough to charge my old iPhone 4. I recently upgraded to the larger LG Optimus G Pro with a HUGE battery and I get a "slow charging" alert when I plug it into my car. Guess I need to find a more powerful USB charger. :?
mgb4tim
Postby working on it » Fri Jun 14, 2013 7:30 pm
I already have an inverter with USB station in the cabin of the trailer, but I found a back-up that I can use if the battery fails, a wind-up flashlight w/USB. Never considered one 'til I saw this one.
http://www.etoncorp.com/en/productdisplay/clipray-1It has a crank arm that will give you ten minutes of power if you crank it twice a second for 60 seconds. Small enough to hang on the wall of the trailer (and it's good exercise in a small dark cabin!) Combined with my SansaFuze MP3 w/radio, and charger cord that fits both my phone and my wife's phone, I can see and get info in case of off-grid battery failure (short-term)...and then there's always my car and/or generator available.
Last edited by working on it on Sat Jun 29, 2013 11:02 pm, edited 1 time in total.
173193172890148599
working on it
Images: 457
Postby Treeview » Sat Jun 15, 2013 8:21 am
I like the Eton unit, for $15 it seemed like a good deal, until I read:
Please note not compatible to charge iPhone 3GS, 4, 4S, or 5.
:NC
Treeview
Images: 30
Postby Bogo » Sat Jun 15, 2013 7:10 pm
For USB charging I'll stick to power supplies that plug into standard cigarette lighter sockets. There are a number of different methods those little units tell the device it has the extra power available. So I'll install multiple cigarette lighter sockets, and put the appropriate power supply in each as needed. I also will be giving each socket it's own power switch/circuit breaker. That way I can turn them on and off as needed. When you are initially building it isn't hard to put 4 or so sockets in.
Bogo
Images: 39
