Z3R0 wrote:I've done some research on this as well as that's what I'm going with. It seems the best tool is to float. Silicone the perimeter and seams. It has a different shrink rate than the wood and if the adhesive is strong enough it could crack. I think they also said to leave a 1/8 inch for expansion on the sides of your profile if you are covering with trim. I think the silicone will also stop it from rattling like crazy down the highway. This was on done on the interior of a boats cabin. Ill see if I can find the forum it was very informative.
doug hodder wrote:A regular RV parts/shop/supplier can get you the 1" x 1/2" trim that will work perfect for you in this situation.
bdosborn wrote:doug hodder wrote:A regular RV parts/shop/supplier can get you the 1" x 1/2" trim that will work perfect for you in this situation.
That's what I used on the second trailer. That stuff is a joy to work with, easily bending to the front radius. I tempered aluminum angle from the home center and bent it for the first trailer. What a PITA that was!
