Hardware suggestions for a pass-through drawer please.
Postby hwitten » Tue Jun 18, 2013 7:47 pm
Did my first real trip. It was part work, part shakedown. I ended up eating a cold lunch rather than set up the camp stove so I'm pondering a pass-through drawer in my storage area. A drawer that can be pulled out from either side. The camp stove will be mounted permanently on one end so it can be in use by simply opening the door. While it seems like a minor task to set up the stove, it simply won't get done when travelling.
Any suggestions as to hardware that might be suitable will be appreciated. I know that pass-through drawers are in use in many RV "basements" but I fear that's a bit of an overkill, I.e. heavier than necessary.
Will be removing the other center support in the storage area to make room.
hwitten
Re: Hardware suggestions for a pass-through drawer please.
Postby mezmo » Wed Jun 19, 2013 3:08 am
To do a low tech approach, and since you have bottom lips up
from the floor under the cargo doors, try putting a 1x or ripped
piece of 1/2to3/4in thick plywood at least half the height of the space
from the floor to the bed bottom, on edge spanning to each side of the
compartment, lined up with the compartment opening's sides.
Their point being, to locate and guide the new 'Dr. Doolittle Drawer'.
["It comes this way, then goes that way."] Then, get some cheap
unidirectional castors, and mount them on a 1/4in to 3/8in thick piece
of plywood [with short screws or small machine screws and nuts
from the underneath, or even appropriate sized pop-rivets done
from the underneath], sized to the opening area between the sides
of the cargo doors [Just make the plywood piece only just wide
enough to still be able to be inserted through the doors.]. Space
the unidirectional castors on a 4-to-6in grid, at least 3 in a row.
This piece of plywood, with the unidirectional castors mounted
in a grid pattern on it, should then be mounted on the trailer floor
between the 1x guide boards with the castor wheels pointing upwards
from the floor for the bottom of the full one piece drawer to roll upon.
[Just make sure the unidirectional castors wheels are pointed all the
same way in the direction(s) [here, back and forth] you want the drawer
to roll in. - Not trying to state the obvious, but it'd be really easy to
accidentally get them out of position when installing them on the
plywood piece.]
Then, build the full trailer-width drawer, sized to fit through the side
cargo door openings. Use 'hole" handles on each end to eliminate any
need for hardware. For a 'tight' fit, you could radius the bottom long
edges to fit the shape of the cargo door radius by tracing that onto your
drawer ends and at least one interior divider. [Allow ~1/8-1/4in clearance
on each side too.] Then cut the bottom and the sides of the drawer to
the width needed to fit the straight dimensions of the radiused drawer
ends. The long edge gap between them can be filled with a smaller and
narrower board beveled on each edge 45 degrees to fit against the larger
pieces. [There are many ways to approach this.] You could also mount a
few [3 to 4 at least on each side, I'd say] wheels from castors, or such,
on their sides on the top edges [using appropriate length screws to
position and locate them while still allowing them to roll] of the two 1x
side guide boards to act as roller guides for the sides of the big drawer.
Of course, you'd want to add a slide bolt or two, or such, to secure the
drawer in place when traveling.
Just an approach for your consideration. You'll lose some cubic inches
of storage volume due to the raised lower lips from the cargo doors, so
this approach would use that space for a way to suspend and guide the
drawer, via the inverted castors and the side guide boards which would
guide the drawer and also keep other items stored under the bed away
from the drawer so that it can move smoothly without interference.
Good luck with whatever you decide to do.
Norm/mezmo
mezmo
Images: 194
Postby hwitten » Wed Jun 19, 2013 4:13 pm
Thanks Norm.
That's an approach I hadn't considered. Going to do some experimenting.
Heinz
hwitten
Postby goldcoop » Wed Jun 19, 2013 6:23 pm
http://www.leevalley.com/US/Hardware/pa ... 51976&ap=1
And a couple of cleats for tracks...
Coop
goldcoop
Images: 32
Postby hwitten » Sat Jun 29, 2013 9:57 pm
After some trial and error measuring and re-thinking I decided on a 90 degree turn about. Instead of doing a pass-through I decided to do a drawer to the inside, using bottom mount slides. Gives me a 36x19 inch storage for clothes and other people items that will be easily accessible from inside.
For the easy access cooking for that quick pot of coffee I decided to go with a single burner coleman.
Finished the drawer today. Sliders should be here Tuesday.
Heinz
hwitten
Postby pchast » Sun Jun 30, 2013 8:06 pm
I've lost track of what exactly you are building But:
Combustion inside a closed camper could be dangerous.
Don't you think an electric hot cup would be safer?
pchast
Images: 97
Postby hwitten » Sun Jun 30, 2013 8:18 pm
No plans for inside Coleman cooking.
It's just that the single burner will be much easier/quicker to setup on table/ground.
For that coffee in bed I am considering a Coffee Maker by Power Hunt. Anyone have one?
http://www.power-huntstore.com/12_Volt_ ... np-301.htm
hwitten
Postby GuitarPhotog » Sun Jun 30, 2013 10:12 pm
hwitten wrote:No plans for inside Coleman cooking.
25 Amps, yeouch! And a special connector required in the bargain. You won't make many cups of coffee per battery charge with that, unless you're running from shore power. In which case just use a 120 VAC coffee maker.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby hwitten » Sun Jun 30, 2013 10:15 pm
But only for 3 minutes :)
hwitten
Postby hwitten » Wed Jul 03, 2013 6:34 pm
Got my big a.s'd sliders in today. Installed and looking/working good. Should have ample storage in living area now for people stuffs.
36 inch slides
Some items that I had originally stored in trailer will now be hauled in back of TV, I.e. lawn chairs. I still have some Motorhome mentality left over, thinking that everything has to be in same vehicle. Slowly adjusting to new environment. :)
hwitten
Postby Vedette » Fri Jul 05, 2013 11:10 am
Well Heinz
We are finally loading our TV today (Hyundai Santa Fe) and we are off!
Hope all the storage areas and gadgets I built work as planned??? :thinking:
Good Luck with your project....hope to see it this Fall! :thumbsup:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
