A/C clearance
A/C clearance
Postby MikeyLikesIt » Tue Jul 16, 2013 10:01 pm
How much clearance should i have around my A/C? Right now i have 6" in the back and 4" on each side. The bottom is completely open.
The A/C only blows cool for about 5 minutes and then it's just warm air. It doesn't appear to be freezing up. Did i just get a dud A/C?
MikeyLikesIt
Re: A/C clearance
Postby asianflava » Tue Jul 16, 2013 10:05 pm
You need to separate the cool that goes thru the condenser from the hot air that exhausts out of it. The intake air comes in thru the sides and the hot exhaust goes out the back.
asianflava
Re: A/C clearance
Postby Mukilteo » Tue Jul 16, 2013 10:24 pm
asianflava wrote:You need to separate the cool that goes thru the condenser from the hot air that exhausts out of it. The intake air comes in thru the sides and the hot exhaust goes out the back.
:thumbsup: :thumbsup:
Eric
Mukilteo
Images: 18
Re: A/C clearance
Postby Bogo » Wed Jul 17, 2013 12:00 am
You should be able to use some foam walls to do the separation.
Also try to deflect the exhaust air away so the intake doesn't just suck it back in.
Bogo
Images: 39
Re: A/C clearance
Postby asianflava » Wed Jul 17, 2013 12:08 am
Bogo wrote:You should be able to use some foam walls to do the separation.
Like this:
asianflava
Re: A/C clearance
Postby MikeyLikesIt » Wed Jul 17, 2013 5:28 am
Thanks, I'll give that a try when I get home today.
MikeyLikesIt
Re: A/C clearance
Postby planovet » Wed Jul 17, 2013 10:05 am
Pretty much this.
I vented mine out the bottom and made sure the two were as separate as I could make it. Works fine for me.
ImageMark (& Cindi)
planovet
The Cat Man
Re: A/C clearance
Postby MikeyLikesIt » Wed Jul 17, 2013 3:34 pm
Walls installed.
And sealed up.
I'll give it an hour or 2 and check back.
MikeyLikesIt
Re: A/C clearance
Postby MikeyLikesIt » Wed Jul 17, 2013 5:07 pm
After 90 minutes the temp read 84 degrees. I think this may have solved my problem. Thanks for all the input.
I'm going to let it run a few more hours and see if I can get it sleeping comfortable. The CRA is just around the corner and Indiana has been blazing this week!
MikeyLikesIt
Re: A/C clearance
Postby MikeyLikesIt » Wed Jul 17, 2013 9:57 pm
6 hours and I've reached 70 degrees.
MikeyLikesIt
Re: A/C clearance
Postby Bogo » Wed Jul 17, 2013 10:17 pm
Was that 6 hours with a human inside? We output quite a few watts of heat and a bit of humidity too. You'll also need a fresh air supply due to the small interior volume of the TD.
Bogo
Images: 39
Re: A/C clearance
Postby MikeyLikesIt » Wed Jul 17, 2013 10:28 pm
No human and this is more of a canned ham.
MikeyLikesIt
Re: A/C clearance
Postby asianflava » Thu Jul 18, 2013 12:10 am
Do you have a separate fresh air intake and hot exhaust?
asianflava
Re: A/C clearance
Postby MikeyLikesIt » Thu Jul 18, 2013 6:44 am
asianflava wrote:Do you have a separate fresh air intake and hot exhaust?
They are divided by a 2x4 that rests on my frame.
MikeyLikesIt
