by Kody » Tue Jul 30, 2013 10:19 pm
I don't know what brands of drills you fellas have over there, so I can't comment on the quality of the brands. However, High Speed Steel drills are not all the same in quality. Yes, they are made from High Speed Steel (HSS) but there is both high and low quality to be found in this material. I will never buy a drill made in China as 99% of these are junk. The best drills are made in the US and Australia and these are the easiest ones to obtain. Cobalt drills are made from HSS with the addition of Cobalt to add extra hardness, heat resistance and especially toughness. The bad thing about Cobalt drills is that they are rather brittle and can snap if they are dropped onto a concrete floor. You will also pay more for these drills but they are certainly worth the extra expense. If you want the best drill of all for drilling metal (and also wood) buy the "TiN" coated style. These are recognized by the beautiful bright "gold" plating on the drill from the cutting point to where it is held in the chuck. The coating is Titanium Nitride and produces an intensely hard and "slippery" surface, slippery means a surface with an extremely low coefficient of friction. These drills are wonderful for drilling aluminium and deep holes in steel. The TiN coating is also applied to the end of the drill when it is made. Don't be afraid to sharpen these drills, The TiN coating on the end is lost when sharpening, obviously, but the quality and performance of the drill still remains. It is the coating on the surface of the flutes that does the work. This is where the swarf/cuttings slide up to be expelled from the hole. The drills cut so much better than anything I have used. However, some manufacturers (like in China) coat their cheap and nasty drills with TiN so you need to be very careful of what you buy and where you buy it from. The best guide to quality is the price but look to see where it is made.
Some drills are completely black in colour when you buy them. This is an oxide coating but I'm not certain what it consists of. The advantage of these black drills is that they resist corrosion much better than a standard form of HSS drill. There are other coatings on drills but they start to become cost prohibitive, an example is Titanium Carbon Nitride (TiCN) and Titanium Aluminium Nitride (TiAIN). These drills are superior to the standard TiN coated ones and you will pay a lot more for these. They are not necessary in the home workshop.
When you sharpen your drills, it is best to grind them down on a "coarse" grit wheel as this is much quicker to do. When you complete the finish grind, always use a fine grit wheel to produce a fine smooth finish on the cutting point and the edges of the flutes. A smooth finish adds greatly to the life of the cutting edges and cuts better with more accuracy.
Every drill I now buy either as a new size or as a replacement, is TiN coated, they are definitely the best. Cobalt drills are also available as TiN coated.
Hope this helps a bit more,
Kody
Never be afraid to ask questions here, Prov. 11:14
