jstrubberg wrote:Ceiling height isn't usually a consideration in a teardrop. Unless you are abnormally tall, you aren't going to miss the 3 inches.
But why not have the best of both worlds? Cut the sidewalls 3 inches taller and forge ahead!
RandyG wrote:Lifting the floor has some advantages, you'll gain the height and the end grain will be tucked away. Just make sure the walls are attached to something solid. What is your floor made of?
jstrubberg wrote:Hrm,
When you say Putting the walls on top of the floor, wouldn't that put you trying to screw into the end grain of the wall to secure it? Plywood is pretty notorious for not holding a screw put in that way.
Can you bring the wall up level with the bottom of the floor assembly and still gain some height?
TPMcGinty wrote:I used a 2x4 frame with 1/2 inch plywood top and bottom for my floor. After I attached the floor to the trailer, I rested the 3/4 inch plywood walls on top of the trailer frame edge and fastened the walls to the 2 inches of floor the stuck up above the trailer frame. It worked very well. It also gave me 60 inches in interior width which allowed me to put a full queen size mattress inside.
suzart24 wrote:TPMcGinty wrote:I used a 2x4 frame with 1/2 inch plywood top and bottom for my floor. After I attached the floor to the trailer, I rested the 3/4 inch plywood walls on top of the trailer frame edge and fastened the walls to the 2 inches of floor the stuck up above the trailer frame. It worked very well. It also gave me 60 inches in interior width which allowed me to put a full queen size mattress inside.
That's exactly what I'm thinking of doing. ThanX for sharing your experience with me.
Great dog, by the way!
suzart24 wrote:jstrubberg wrote:Hrm,
I'm putting the walls on the top, outside edge, of the trailer frame and agains the side of my floor structure. I would be screwing into the 1 1/2" side of the 2x4s that my 1/2" plywood floor is screwed & glued to.
les45 wrote:I bolted my 5/8 ply floor directly to the trailer frame and then bolted my 2X4 side rails to the floor leaving a 3/4" ledge for my sidewall to sit on. I wanted my black trailer frame exposed to provide contrast to the yellow body. I used 1.5" lattice strips painted black to cover the exposed edges of the plywood floor. I think the extra 3" of headroom inside the cabin makes a big difference.
suzart24 wrote:ThanX!!
That's exactly what I want to do, except my floor is on top of the 2x4s. Is that 2x4 frame board inside your cab?
I'm sealing the topside with epoxy resin and the underside with HENRY'S black goo.
