by eamarquardt » Thu Aug 01, 2013 5:17 pm
I don't agree with some of the things said in earlier posts and some things that have gone unsaid.
You can certainly run the AC back to your trailer and us it to charge your battery.
1) Even if the outlet is "only" 400 watts that's gonna be enough to make nearly 30 amps of 12 volt charging power. More than enough.
2) You can't charge directly from the 120 volt circuit and you'll have to install a charger to convert the 120 volts to 12 volts (more or less) to charge your battery in your trailer.
3) I've never heard of anyone doing this so it's gonna be a bit unusual, someone might get confused and do something you'll wish they hadn't, and you'll have to turn the inverter off when you stop so you don't run down your vehicle's starting battery.
4) Your vehicle's charging system is already 12 volts. The simplest and most common solution is to connect your vehicle's battery/charging system to your trailer's battery to charge it while driving. You should disconnect your trailer when stopped so you don't accidentally discharge your starting battery should there be something running in the trailer. You can do this manually (unplug) or use a relay to disconnect your vehicle from the trailer when the ignition is off.
Hope this clears things up a bit.
Gus
