need welder in Portland Oregon
Postby nikwax » Thu Sep 26, 2013 3:59 pm
I have a tiny trailer that I built 6 years ago on a Harbor Freight chassis. I'm finding that the tongue is too wimpy and I've had problems getting a jack to work well with it.
I need a welder in the Portland, Oregon area to fab a new tongue for me. Suggestions please? Thanks!
nikwax
Images: 30
Re: need welder in Portland Oregon
Postby pchast » Thu Sep 26, 2013 5:54 pm
No reason it couldn't be bolted in If a welder is costly.
Just get grade 8 bolts and drill some holes....
:thinking:
pchast
Images: 97
Postby nikwax » Thu Sep 26, 2013 7:43 pm
pchast wrote:No reason it couldn't be bolted in If a welder is costly.
:thinking:
If I had a stouter tongue, I could bolt it on. That would be safer than welding under a wooden structure, now that you mention it ;-)
nikwax
Images: 30
Postby the hunter » Thu Sep 26, 2013 8:47 pm
tbb truck builders 503 761 8338 hes on 170th and divison very good and reasonable
the hunter
Postby nikwax » Fri Sep 27, 2013 11:53 am
the hunter wrote:tbb truck builders 503 761 8338 hes on 170th and divison very good and reasonable
thanks, I'll check that out!
nikwax
Images: 30
