ok, I'll admit my ignorance..............
Postby darrellbeck » Fri Oct 11, 2013 5:02 pm
Building my first teardrop will give me a chance to show that I don't even know the basics. My question now (and I've tried to research it with no luck) is simply this: Why do people put 1x2's on their frame before putting a floor on? I have never built a camper, but I have built several utility trailers. I didn't put anything between the frame and the floor. Please help me out here, why is it done?
Thanks
Darrell
darrellbeck
Images: 24
Re: ok, I'll admit my ignorance..............
Postby Oldragbaggers » Fri Oct 11, 2013 6:36 pm
I used 1x3's because my floor is insulated. If I hadn't insulated my floor I probably would have just bolted 3/4" plywood directly to the frame.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby Roo Dog » Fri Oct 11, 2013 6:44 pm
Darrell,
Ours is attached direct to the trailer chassis. The floor is carpeted.
It does not snow in our part of Oz and even so we do not venture out much in winter.
RD :)
Lets do a three sixty and get out of here !
Roo Dog
Postby darrellbeck » Fri Oct 11, 2013 8:00 pm
Thanks for the answers. I could not think of a good reason to put the 1x2s on and you guys have made me feel better about this question. The only real reason that I could come up with was if your welds were very rough, (which my welds are not) you might want to place them judicially to keep your floor from having a high spot . I am going to go ahead without them. I, too, will be putting carpet down. When I get my trailer done, I wonder if I could drive to Australia if I really water proofed my trailer? I would sure like to see that country, and that would be the only way I could afford it. Ah, well, as Roy Orbison said, "In dreams I dream of you". Well, maybe not YOU, but your country.
Thanks a lot
Darrell
darrellbeck
Images: 24
Postby RKH » Fri Oct 11, 2013 8:32 pm
Some possible thoughts:
1. A space to run wiring under the floor without being also under the frame.
2. To give you a place to attach the sides other than the edge of sometimes plywood floor
Just Possible considerations.
~Keith
Support Our Troops
Our traveling blog is at http://www.Happy-Tracks.com
RKH
Images: 16
Postby Roo Dog » Fri Oct 11, 2013 8:52 pm
RKH,
The sides of ours are also bolted to the chassis.
RD :)
Roo Dog
Postby Glenn Butcher » Fri Oct 11, 2013 9:15 pm
I'm going to use a 1x3 frame, mainly because I'm building on a 40x48 mini-trailer and I need to build over the fenders to get 4 feet of width.
I got the idea here: http://www.tnttt.com/viewtopic.php?f=50&t=55602
Glenn Butcher
Images: 16
Postby AlgoDan » Sat Oct 12, 2013 5:20 am
I went with 2x3 frame so the whole unit can come off the actual trailer for future use...
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby Shadow Catcher » Sat Oct 12, 2013 6:41 am
Ignorance is easily curable and we will not give you a hard time for asking.
The only insulation on the floor of CR is the 5" foam mattress.
Postby Mary C » Sun Oct 13, 2013 7:44 am
Darrell, I wanted to build 5 ft wide on a 4ft wide trailer, to do that I used 1x4s and 2x4s on their side and built a frame so that it would be high enough to go over the wheel wells. thus making a 5 ft wide base support for my floor.
Good Luck and we don't mind the questions.
Mary C. :)
Mary C
Images: 473
Postby eggsalad » Sun Oct 13, 2013 6:18 pm
I have nothing between my floor and trailer, either (aside from paint and primer). Heck, I didn't even use 3/4" ply - I used 1/2", to save money and weight.
eggsalad
