Starting over.
Starting over.
Postby coyote » Fri Nov 15, 2013 12:42 pm
I don't post much, don't know much. But, I'm a bit frustrated. I'm close to putting up sides and making some visual impact. Towed basic frame to work yesterday to weld on a little bracket. Asked and received permission for everything. BAM, an employee ran a company 1 ton truck over the back of it!
Hooked to car on front, duelleys on top of rear, axle as fulcrum. Well, my welds held, but whew...I can't save much more than my new Monroe's and tires. ( plus the guy tried to drive off)
Oh, I know insurance, it'll be ok. But. . . . On the positive, I guess I can fix any of those "I wish I had of. . . " and it wasn't my car or a group of first graders. I sure thought of whoever it was that got rear ended on his.
Thanks, I just needed to vent a bit. Dave
coyote
Titanium Donating Member
Re: Starting over.
Postby Mary C » Fri Nov 15, 2013 1:53 pm
Bummer!!! I feel for ya. Now you can make any changes but is is your time and work that cant be recovered, it makes an impact in every day things when something in your life is destroyed in a second. Did you get any pictures?
Good luck on the next one.
Mary C. :)
Mary C
Images: 473
Re: Starting over.
Postby coyote » Fri Nov 15, 2013 2:08 pm
Yeah, lost all those hours of engineering, but it will go faster, and the thinking part has been done. "They" got images. When I get it figured out I will put one on here. dave
coyote
Re: Starting over.
Postby Rhino Ray » Fri Nov 15, 2013 2:28 pm
Man, I didn't see that coming. :shocked: Glad it wasn't further along too. What was he thinking? :scratchthinking:
Good luck on your rebuild, at least you know that the welds will be good.
The eleventh commandment: Ye that snoozeth loozeth. Selling real estate in ALL of Jefferson State (Northern California and Southern Oregon)
My Build http://www.tnttt.com/viewtopic.php?f=21&t=49746
Rhino Ray
Images: 60
Re: Starting over.
Postby Junkboy999 » Sun Nov 24, 2013 8:15 pm
Ouch. Boy that bites. :(
I think Brian have somthing like that happen to miss piggy. He was pulling it to go get painted of something like that and BAM someone hit him. He is a body man so he fixed it but all that work down the drain.
Junkboy999
Images: 52
Re: Starting over
Postby coyote » Tue Nov 26, 2013 11:15 am
Well, almost back together. Got a new frame, boxed It, installed shock mounts, cleaned/packed wheel brgs, moved axle back. 11 days and I'm back to where I was. Well, a 1/2hour of welding or so. Then uncharted territory! Need to take it to work to do that welding but, I think I'll go after the day crew leaves! Dave
coyote
Re: Starting over.
Postby campmaster-k » Tue Nov 26, 2013 6:16 pm
Awesome. Pictures please. :pictures:
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: Starting over
Postby Rhino Ray » Tue Nov 26, 2013 8:03 pm
coyote wrote:Well, almost back together. Got a new frame, boxed It, installed shock mounts, cleaned/packed wheel brgs, moved axle back. 11 days and I'm back to where I was. Well, a 1/2hour of welding or so. Then uncharted territory! Need to take it to work to do that welding but, I think I'll go after the day crew leaves! Dave
Smart move. :eyebrows:
Rhino Ray
Images: 60
Re: Starting over.
Postby coyote » Fri May 23, 2014 12:00 pm
120497 We finally got it together, made it to Dallas, Louisiana, Arkansas and home on maiden voyage. 1250 miles, no problems. :worship: Thanks to crushing, I have hub, bearings and seals, spare tire. :lol:
coyote
Re: Starting over.
Postby Shadow Catcher » Sat May 24, 2014 5:55 am
Absolutely the optimal out come. Looks good, have fun.
