Need Battery Upgrade Advise
Postby bdosborn » Thu Feb 20, 2014 10:03 pm
I've been looking around for a new set of batteries to replace my failing Deka golf cart batteries. Has anybody heard of C&D batteries?
On closer look, they have a little bit of lead sulphate slough.
But I can definitely get plenty of amp-hr capacity:
Voltage drop wont be a problem, there's plenty of cable capacity. They come with 4 sets of 600 kcmil cables:
What do you think, should I pull the trigger on these? I'm not sure I have enough PV capacity to charge them, anybody know about what the C8 capacity of the string should be? It will carry 750kW for 10 minutes.
Images: 806
Re: Need Battery Upgrade Advise
Postby MtnDon » Thu Feb 20, 2014 10:09 pm
Uh... :thinking: You might need a bigger trailer. :lol:
MtnDon
Images: 24
Postby Redneck Teepee » Thu Feb 20, 2014 10:23 pm
MtnDon wrote:Uh... :thinking: You might need a bigger trailer. :lol:
Or a Submarine! :D
Redneck Teepee
Images: 21
Postby Verna » Thu Feb 20, 2014 10:25 pm
As a former telephone company central office tech, I miss seeing those, Bruce !! Thanks !
Verna
Indianapolis, IN
Verna
Images: 49
Postby eamarquardt » Fri Feb 21, 2014 5:20 am
In a pinch you might be able to generate enough current to weld.
-Gus-
eamarquardt
Images: 150
Postby bdosborn » Fri Feb 21, 2014 8:19 am
eamarquardt wrote:In a pinch you might be able to generate enough current to weld.
We'll lets see; It's a 500V string and it will carry a 750kW load. That's 1,500 amps, would that be enough to weld with? :? :lol:
Images: 806
Postby Dale M. » Fri Feb 21, 2014 10:51 am
C&D make a great battery for industrial "backup storage" installations, telephone offices use many of them, and I have wrestled with many of them in my career as a communications tech.......
Not aware of smaller batteries (golf cart size) if the make them, but if they do, the quality will be good....
Dale
Dale M.
Images: 18
