Decent Caulking gun?
Postby tony.latham » Fri Feb 21, 2014 10:23 pm
I don't know how many tubes of adhesive I squeezed on my built last summer but I'm tired of $4.99 junker caulk guns. I'm looking for a good 25 oz gun.
Anybody got one they swear by?
Thanks,
Re: Decent Caulking gun?
Postby MtnDon » Fri Feb 21, 2014 10:44 pm
Well, if you can live with 10 oz. tubes and a $240 price tag have a look at the Makita 18V LXT. Makita tools last forever. It will permit you to cut a very small opening at the tube tip for precise control. You can't do that by hand. The Makita has more pressure than most any other gun and can do it all day long.
MtnDon
Images: 24
Postby tony.latham » Fri Feb 21, 2014 11:29 pm
MtnDon wrote:Well, if you can live with 10 oz. tubes and a $240 price tag have a look at the Makita 18V LXT. Makita tools last forever. It will permit you to cut a very small opening at the tube tip for precise control. You can't do that by hand. The Makita has more pressure than most any other gun and can do it all day long.
Don: $240 is waaaaay outta my price range for a caulking gun, but thanks.
Postby jonw » Sat Feb 22, 2014 3:22 am
I have a Ryobi that uses 10oz. tubes that I like. Uses 18v batteries same as my cordless drill. Was about $30 on sale at HD IIRC....
jonw
Titanium Donating Member
Images: 163
Postby aggie79 » Sat Feb 22, 2014 9:58 am
jonw wrote:I have a Ryobi that uses 10oz. tubes that I like. Uses 18v batteries same ss my cordless drill. Was about $30 on sale at HD IIRC....
I'm with Jon. I too have the Ryobi and have run well over 200 tubes using it. My arthritic wrists can't stand up to a regular caulk gun.
Postby kayakdlk » Sat Feb 22, 2014 10:02 am
For my PL premium glue I bought it in the big tubes and just cut the top off and used a broom handle to push the whole thing out into a disposable tray and then used a trowel to spread the glue. Worked a lot better that trying to squeeze it out.
Dan
kayakdlk
Images: 392
Postby Fenlason » Mon Feb 24, 2014 10:02 am
I have a nice "conventional" caulking gun. I don't know if there is a name on it. [It's out in the barn and I am sick on the couch right now] I have had it some years now. The price was maybe between $10.00 and $20.00 dollars. It is more durable and works better than the previous cheapies I have had. It has a built in place to cut the end of the tube open and has a build in rod to poke the inner hole open.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Tour de Post Yellow Jersey
Images: 221
Postby rowerwet » Mon Feb 24, 2014 8:57 pm
same here, ^ only mine is also made with a ring that you put the tip of the tube into instead of a U shaped end, http://www.factsfacts.com/MyHomeRepair/ ... ingGun.jpg the end is held by a "beam" on the top and bottom, no matter how much force you put on it, it can't deform. They had these at HD for a while, since then they've gone to a design with the beams running down each side and an open slot at the top.Those stamped, spot welded cheapies end up in my scrap metal bin.
rowerwet
Images: 521
Postby Prototear » Tue Feb 25, 2014 3:37 am
My brother is a professional house painter and he threw out my cheapie gun and got me a Dripless caulk gun when painting my house. It is the SH200 and is at Home Depot for less than $6 (but might not be just online now). I've had it for 7+ years for various tasks around the house and it is still my preferred, most reliable caulk gun. Not only does it hold good pressure, it also does not drip when you set it down (like the name implies) because of the friction action in the trigger rather than the clicking ratchet teeth like others have. It also has a built in tip trimmer and a pin to break the tube seal. 8)
It looks almost like a regular gun, but as Rowerwet describes, the tube goes in from the side. Most of the Dripless models go into a tray on the top. http://www.dripless.com/caulkguns3.html
http://www.homedepot.com/p/Dripless-10-oz-SH200-Skeleton-Hex-Rod-12-1-Caulk-Gun-15788/204141750
First Build: viewtopic.php?f=50&t=57021
Prototear
Images: 412
Postby Fenlason » Tue Feb 25, 2014 7:35 am
rowerwet wrote:same here, ^ only mine is also made with a ring that you put the tip of the tube into instead of a U shaped end, http://www.factsfacts.com/MyHomeRepair/ ... ingGun.jpg the end is held by a "beam" on the top and bottom, no matter how much force you put on it, it can't deform. They had these at HD for a while, since then they've gone to a design with the beams running down each side and an open slot at the top.Those stamped, spot welded cheapies end up in my scrap metal bin.
That might be what I have. I tend to purchase my tools at a local lumberyard vs Home Depot, but I might have bought that there. Anyways… mine looks like that ^ and It works great!! :thumbsup:
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby rowerwet » Tue Feb 25, 2014 7:47 am
I got mine first to use at work, fuel tanks, windows, and pressurized hulls are all sealed with this nasty two part stuff that dries to a rubbery texture, it is called PRC for short. since it is rather thick when wet, and the real guns used to spread it are expensive, I trashed a few cheapies until I found the caulking gun in the picture, been using one at work for 5 or 6 years now with no issues. If the gun can handle that, no adhesive or caulk will hurt it.
rowerwet
Images: 521
Postby Fenlason » Tue Feb 25, 2014 8:14 am
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby tony.latham » Wed Feb 26, 2014 12:53 am
slowcowboy wrote:My first build used no from of adivise just deck sqrews in numorous sizes and quantys.
my 2 build will probaly use construtction adivise in limeted use.
what about the air operated caulking guns from wally world?
slow
Slow: Do they make them for the large 28 ounce tubes? You save a lot of money by buying the big tubes.
Postby Redneck Teepee » Wed Feb 26, 2014 10:31 am
slow
Just one place to get the 28 oz guns.....http://www.mcmaster.com/#caulk-guns/=qv22xv
Redneck Teepee
Images: 21
