Page 16 shows the vertical dimension of the aft bulkhead as 4 3/8. Is this dim from the top of the floor? Or, from where is it taken? (the horizontal line isn't defined). I'm trying to get a feel for the correlation between the two dims, 4 3/8 and 5 1/8.
I see the 3 1/8 dim on page 6. Above this top horizontal line for this dim are two more horizontal lines. Can I assume that the first one is 1 1/2 up and the second is 1/2 up? This still doesn't seem to mesh with the 4 3/8 dim. OK - you see my confusion? Can you help me?
