I've searched and can't quite find the answer to my question. Let's assume that I'm going to use baltic birch on the roof of my TD. We know that it isn't rated for exterior use. So, If I coat the plywood with a coat of epoxy, have I now just made myself the equivalent of an exterior grade plywood? Same question for the 1/8" Luan that I see in the big box stores.
Secondly, can the epoxy be tinted and can UV stabilizers be added such that this is the only coating that would be necessary?
As you can tell, I know next to nothing about epoxy. Varnish, shellac, w/b shellac, latex, o/b & w/b urethanes and poly's, yes. Epoxy, no.
Thanks, Ken
