I think I am starting to lean towards build over buy....
The first salvo of questions;
1) My tow vehicle is a 2014 Subaru XV. I would like to pick up a set of stock wheels from someone changing theirs out. (I like the stockers) This would give me a full-size spare for the XV, a pair for the XV-T, and a spare for the XV-T.
Wheels are 17"x 7", 5 on 100mm bolt pattern. Dexter does 5 on 4.5" hubs, so it looks like adapters will be necessary. Or not?
2) I'm pretty sure I'd like to go with Dexter TorqFlex axles in the 2k to 2.5k range. I plan to keep the gwv as light as possible, and it's just me at the moment, so there won't be a preponderance of gear. I would like the XV-T to be at least as off- road capable as the XV. It's no rock-crawler, but it is all wheel drive. Being light, would elec brakes be necessary, and are TorqFlex's a good choice?
3) Has anyone investigated the use of modular railing components (ie: http://www.hollaender.com/) for frame and cabin construction? I plan to minimize the use of wood to the fullest extent. I don't have a huge garage, and I live in a retirement community, so construction needs to be somewhat considerate and stealthy. The components are rated for 30k and 40k loading, not terribly expensive and aluminum. I would think that Sch80 aluminum tubing would make for a fairly stiff buildup, especially if the joints were through-bolted in place of the set screws. Or even welded.... Do you think CA DOT would have a problem with this type of construction?
I know there'll be more ???, but these are the first ones that come to mind.
