Could these work for windows?
Postby Kullas » Thu Mar 27, 2014 7:26 pm
Chris
Kullas
Re: Could these work for windows?
Postby Woodbutcher » Thu Mar 27, 2014 7:56 pm
Not those windows, but there are some shed windows that are 3 pane awning windows. They only come in white and brown. I have used those and they work well. I like them because you can open them when it rains and still get some air. Only negative is you either need door stops or be real careful when you open the door with the window louvers open. They can poke the side of the trailer.
Woodbutcher
Postby Kullas » Thu Mar 27, 2014 8:18 pm
Chris
Kullas
Postby MtnDon » Thu Mar 27, 2014 8:24 pm
... except that one does not specify safety glass is used. That is a requirement for legal vehicle & trailer use on public roads.
MtnDon
Images: 24
Postby Woodbutcher » Thu Mar 27, 2014 8:56 pm
Kullas wrote:maybe like these? http://www.ebay.com/itm/Crank-Out-Shed-Window-18-x-23-White-Storage-sheds-Barn-Jalousie-Playhouse-/121229796259?pt=LH_DefaultDomain_0&hash=item1c39dbe3a3
Those are the ones, yes. Can't say for sure about the safety glass. My understanding is all glass sold for commercial use needs to be tempered. Since you are not a reseller I don't think the glass police will find you. If you are concerned about it contact the seller and ask.
Woodbutcher
Postby twinight » Fri Mar 28, 2014 3:32 am
Unlikely they are tempered glass, It is only required above bathtubs/showers, if less than 18" above the floor, or with 12" of a door swing.
twinight
Images: 68
Postby goldcoop » Fri Mar 28, 2014 4:51 pm
I used these on my build:
http://mobilemart.com/product.aspx?p=86000
Safety glass!
Coop
goldcoop
Images: 32
Postby Kullas » Fri Mar 28, 2014 4:59 pm
Looks like a winder to me :)
Chris
Kullas
Postby Woodbutcher » Fri Mar 28, 2014 6:39 pm
Says they will not ship those windows. Pick up only at one of their Oklahoma stores only.
Woodbutcher
Postby Woodbutcher » Fri Mar 28, 2014 9:23 pm
If you go back to this link, they have lots of other windows. Many have safety glass. It may be worth asking them if these do, if this is the style you want.
Woodbutcher
Postby Kullas » Fri Mar 28, 2014 9:57 pm
To be honest with you i have two doors to put windows in and i just want to get out as cheep as i can. just need some fresh air in the night
Chris
Kullas
Postby Mary C » Fri Mar 28, 2014 11:02 pm
Hi. I live out in west GA , You might want to check out Wiley windows. I really thought they would be difficult but they really easy to build and you can use plexie glass. Go to the Foamie section and check out pg 27 of the Grits build. and remember I am a 64 year old woman and if I can, you can.
Mary C. :lady:
Mary C
Images: 473
