TD window placement
TD window placement
Postby Socal Tom » Sun Mar 30, 2014 2:11 pm
This may have been covered before, but it recently occured to me that I should have placed the windows in my TD much lower in the door.
Most of us have roof vents, so hot air can get out. Some installed power vents to help pull that hot air out, but the cool air has to come in the window. Well my window is about 18 inches from the top of the TD. I sleep about 10 inches from the bottom, so any air that comes in doesnt create a breeze I could feel. If the window were lower in the door I would feel the breeze. Anyone else see it this way?
It might look a little funny, but it would be much more functional. Any other thoughts on this?
Socal Tom
Re: TD window placement
Postby 48Rob » Sun Mar 30, 2014 6:20 pm
Tom,
Yes, I do as well.
On our first teardrop we placed a small window in the front, so the breeze would blow across us (no A/C in that trailer).
Rob
48Rob
Postby working on it » Sun Mar 30, 2014 8:48 pm
Socal Tom wrote:This may have been covered before, but it recently occured to me that I should have placed the windows in my TD much lower in the door.
My windows are high-mounted also, and I do have powered vents to create an air exchange, but in Texas, the air thru the windows is most likely to be warm or hot during camping season. A/C and/or a higher powered circulating fan were always a "given" in my build. My windows are also not in the doors, for reasons I have stated in other threads, and high-mounted to a) avoid inadvertent contact while sleeping (a 4x8 is sorta tight), and b) provide some privacy with the shades drawn back and window opened (awning style, providing rain-shielding and a "distance barrier" to discourage close by, nose to the glass, snoopers). My wife wanted privacy, but with windows. I prefer a cave.... In a more friendly climate (weather and social), in another time, I would have the windows and doors opened wide for sleeping, but not here and not now.
173193172890148599
working on it
Images: 457
Postby rowerwet » Tue Apr 01, 2014 8:09 pm
my windows are set low in the door and are as large as I could fit to give me as much airflow as possible. sleeping on those perfect nights the air flows in and across me keeping it all comfortable. When I had an RV slider window I didn't get that kind of airflow as even fully open, the window was 2/3 blocked. The Wiley window made the difference, as the glass can come out completely.
look at many tears and wonder why the widows are so small, mine give me the idea of a screen door without any extra parts to get in the way. the bottom of the window is about 4" above the mattress.
rowerwet
Images: 521
Postby Steve_Cox » Tue Apr 01, 2014 10:02 pm
My TD door mounted windows were above me a bit when laying in bed, however I had a Fantastic Fan, so with curtains a little longer than the window, the curtains acted like a wind deflector causing the airflow to go downward toward the bed. Never had a problem when it was "having the windows open season" in Florida. When it was hot the A/C was on. I had 15" X 18" awning windows I got from Grant at Lil Bear. With awning windows you get the full opening vs part opening with sliding windows.
Steve_Cox
Images: 196
Postby Jim Edgerly » Wed Apr 02, 2014 6:03 am
My windows are about a foot above the mattress. Like Steve said, my curtains deflect the air flow drawn in by the powered vent down a little, but not so much that I feel a draft across my body. I have never felt "hot" in my camper, and I have never kept my power vent on for more than an hour at a time (I put it on a switch...always on or on a timer, see below). I do have fans above the pillows to circulate the air which helps cool me without bringing in outside air because sometimes I need a little "air" but the air out side is just to cold to feel comfortable.
Photo of my "power panel" directly above my head as I sleep.
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Jim Edgerly
Images: 142
Users browsing this forum: Bing [Bot] and 6 guests
