Fortunately, I live in a desert, so condensation really doesn't become an issue. As you'll see, this tiny chiller doesn't use the sort of ice that becomes water vapor, either.
Also, being as this device is really tiny, it can only work in a very tiny trailer. My trailer is <80 cu. ft. in volume. I don't anticipate a huge temperature drop nor a long cooling time. This is something I knocked together with stuff around the house and the shop, so it doesn't cost a penny to try. I like that.
I didn't take pictures along the way, but once you see the finished product, the steps will become obvious.
I started with an old Desktop PC power supply. I gutted out everything but the fan, and I flipped the fan around so it blew *inside* the case, not outside. I cut a hole in the top, and replaced it with a steel plate on some spring hinges I had lying around. Now on to the pictures so you can see...
Pretty simple so far, huh? Now what's the mystery chilling medium?
Yup! Lunch cooler packs! They might sweat a bit, but not like plain ol' ice would!
So there it is, pretty simple. It's a bit chilly outside to test it, but it will be warm soon enough and I'll post some results.
