I'm amazed I didn't lose my trailer - I should have.
Postby eggsalad » Fri Apr 11, 2014 2:54 pm
Just back from the first *real* camp in The Coffin. Everything went really well, except I did a very stupid thing that should have cost me my trailer. I'm amazed that it didn't!
Did everything by the book hooking up my trailer. Then I pulled it out of the side yard and on to the street, where I did a full pre-flight check. Everything seemed to pass, so I made my 100-mile journey.
After arriving and backing the trailer to un-hitch, I released the coupler and pulled. Instead of the coupler coming off the ball, the drawbar came out of the hitch! Upon inspection, I found that I put the hitch pin BEHIND the drawbar instead of THROUGH it.
100 miles of urban, highway and gravel road, at speeds of up to 65mph. Somehow, the drawbar NEVER pulled out of the hitch. I'm incredibly happy, but also amazed and perplexed. How come I didn't lose my trailer? (or at least drag it by the safety chains)
eggsalad
Re: I'm amazed I didn't lose my trailer - I should have.
Postby nrody » Fri Apr 11, 2014 3:01 pm
Lucky- You must have a powerful guardian angle
nrody
Nancy
nrody
Postby Juneaudave » Fri Apr 11, 2014 3:08 pm
Wowzer...Your safety chains must have just been tight enough to prevent the hitch from pulling out of the receiver. That or the angel on your shoulder!!! :thumbsup:
Juneaudave
Images: 380
Postby Woodbutcher » Fri Apr 11, 2014 6:27 pm
Holy Crap! You better get out and buy a lottery ticket before it's to late.
Woodbutcher
Postby PKCSPT » Fri Apr 11, 2014 7:12 pm
I am with Woodbutcher, time to play the lottery
121172 116946 159644
PKCSPT
Images: 61
Postby tony.latham » Fri Apr 11, 2014 8:38 pm
And why is it called The Coffin? :R
Glad it made it home! :beer:
TL
p.s. BTW -Thanks for sharing that. It took a set of brass round things. It's one more thing I'll make sure I check.
Postby eggsalad » Fri Apr 11, 2014 8:44 pm
tony.latham wrote:And why is it called The Coffin? :R
TL
Well, because it looks like one!
eggsalad
Postby working on it » Fri Apr 11, 2014 10:59 pm
I wouldn't have dared to call my trailer a suggestively-negative term like the "Coffin", for fear of invoking bad karma, or bad ju-ju, or whatever other adverse energy that seems to be drawn to me. You must be on the other side of the "force". Or else, your drawbar was either rusted in place, or subject to temporary intermolecular bonding, or there was a magneto-gravitometric anomaly occurring at the TV-trailer interface. Or you were just very lucky.
173193172890148599
working on it
Images: 457
Postby TESKELLY » Fri Apr 11, 2014 11:12 pm
Lucky for sure. My guesses are that it was slipping back and forth but the chains were tight enough to prevent it from coming all the way out or you just had enough upward or downward pressure on the receiver that it simply wouldn't budge. You would have needed to be at some point completely level and had very very little tongue weight for it to have slipped right out. Lucky for sure :angel:
TESKELLY
Images: 19
Postby tonyj » Sat Apr 12, 2014 12:53 am
Don't ask why-- just say "thank-you", and don't ever make that mistake again.
(and i thought I had guardian angels...)
tony
tonyj
Images: 160
Postby S. Heisley » Sat Apr 12, 2014 1:20 am
tonyj wrote:Don't ask why-- just say "thank-you", and don't ever make that mistake again.
:yes: :thumbsup:
Postby Shadow Catcher » Sat Apr 12, 2014 6:33 am
It is useful for the rest of us however to have this reminder, and it gives me the opportunity to remind you all about adjusting the coupler or you could end up with this. There is a nut and it needs top be adjusted to the ball or it can come off!
905789058091356
Postby Redneck Teepee » Sat Apr 12, 2014 9:32 am
All of my plug-in hitches have a line of paint (I prefer yellow) on the side that is inserted, at the "stop here" or proper depth, you do not see it when inserted. When un-installed 1/2 is yellow and the other 1/2 is black or what ever you like your exposed part of the hitch to be. It also helps with hole alignment for the pin and prevents things like this....just another idea. :thumbsup:
Redneck Teepee
Images: 21
Postby Vedette » Sat Apr 12, 2014 10:12 am
Shadow Catcher wrote:It is useful for the rest of us however to have this reminder, and it gives me the opportunity to remind you all about adjusting the coupler or you could end up with this. There is a nut and it needs top be adjusted to the ball or it can come off!
905789058091356
My feelings exactly!
Great warning for the start of the camping season.
I will be adding it to my check list for sure.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby eggsalad » Sat Apr 12, 2014 1:29 pm
Redneck Teepee wrote:All of my plug-in hitches have a line of paint (I prefer yellow) on the side that is inserted, at the "stop here" or proper depth, you do not see it when inserted. When un-installed 1/2 is yellow and the other 1/2 is black or what ever you like your exposed part of the hitch to be. It also helps with hole alignment for the pin and prevents things like this....just another idea. :thumbsup:
Yep, that was the idea I came up with as well. It will definitely be happening before the next tow!
eggsalad
