Fresh Water Tanks
Fresh Water Tanks
Postby Atomic77 » Mon Apr 14, 2014 3:40 pm
While looking at fresh water tanks, I'm noticing they are listed as "pressurized" and "non-pressurized" tanks. Besides the obvious, one is pressurized and one isn't, what are the differences in application? Thanks!
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Re: Fresh Water Tanks
Postby Redneck Teepee » Mon Apr 14, 2014 4:09 pm
The pressurized tank will have the water pumped into it under pressure with a rubber diaphragm separating the water and air at the high point and the whole system will be pressurized, it will also have domed ends.... think of a pump and well system for a house.
The non pressurized will simply be a holding tank, square, rectangle, etc. that will only have to deal with inches of water column pressure (about a half a pound per 12 inches, think 5 gallon bucket) with a feed tube off the bottom to either a spigot/valve for gravity flow, or a pump to pressurize the line only to your valved outlet. Simply a reservoir Just my 2 cents worth.
Redneck Teepee
Images: 21
Postby GuitarPhotog » Mon Apr 14, 2014 5:26 pm
This guy has lots of non-pressurized (gravity or pump flow) water storage tanks for reasonable prices.
http://www.ebay.com/itm/16-gal-Fresh-wa ... 4897.l4276
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Atomic77 » Mon Apr 14, 2014 8:32 pm
Ok. I'll check those out. Thanks for the replies!
Michael
The Astroliner
Atomic77
Images: 309
