In choosing a location for mounting a spare, try to achieve equilibrium between three factors: ease of access, effect on trailer balance, and effect on trailer appearance (if mounted externally) or storage space (if internally mounted). For further consideration: if mounted under trailer, will it compromise ground clearance? or if mounted on the tongue, will it have an adverse effect on turn radius (and again, on trailer balance)? I mounted mine on the single drawbar tongue (for ease of access and trailer balance), but when I needed to add a larger tonguebox there, I had to design a slide mount to still be able to access the spare... I should've considered the need for more storage (and weight, forward) before attaching a large thru-bolt to hold the spare to the front wall. I was then "committed" to a location ( and basing my planning for trailer balance using its' 35lb weight); I jumped the gun, when choosing the location, but that's the danger in experimenting (later retro-fitting to suit other changes in design)! ...There have been lots of good ideas for spare tire locations and mounts, presented on this forum, some of which I wish I could've used.doris s. wrote:I was wondering if and where everyone secures a spare tire on their teardrop? I usually carry the spare in my truck but I want to bolt it to my teardrop. This is an after thought. I really should have designed a place for it when we built it!
Doris
GuitarPhotog wrote:Why worry about ease of access?
DMcCam wrote:
You can just see how it sits under the galley in this image.
Glenn Butcher wrote:I'm going to mount mine flat, under the tongue. On the NT 40x48 trailer, there's a convenient hole where the tongue meets the frame, so I'm just going to put a bolt through a steel bar to hold it in place, probably about $5 in hardware. It'll also help my tongue weight.
