Transporting thin aluminum sheet
Postby eggsalad » Sun Jul 06, 2014 11:45 pm
I need to re-skin my roof. I've found a source for 4x10 sheet of .025 aluminum. $34 seems fair.
Problem is, I have no way to transport it flat.
If my math is good, I can roll it in to a 3' diameter tube. Times 4' wide, it will fit in my vehicle.
But will I bone myself by doing that? will I ever be able to get it reasonably flat again?
Thanks,
eggsalad
eggsalad
Re: Transporting thin aluminum sheet
Postby Mary C » Mon Jul 07, 2014 9:24 am
I have been wondering how to transport a 1/4 inch sheet of ply wood too ......My brother suggested that I put it on the side of my trailer using some straps over the top to hold, making a sling then put two straps together to go around the trailer to secure the front and back.........I don't know if it will work but I am going to try!!! I am not sure how aluminum will work but maybe laying over the top and strapping it down???
Mary C.
Mary C
Images: 473
Postby bc toys » Mon Jul 07, 2014 9:32 am
egg where you at in vegas and where is your metal at I can get a trailer and help you with it
bc toys
Images: 42
Postby eggsalad » Mon Jul 07, 2014 1:39 pm
bc toys wrote:egg where you at in vegas and where is your metal at I can get a trailer and help you with it
I live on the east side and I can get the metal at Curtis Steel. PM me if you have an idea.
eggsalad
Postby ssutton » Mon Jul 07, 2014 2:23 pm
Only certain grades of aluminum can be rolled and naturally return to the flat state. Aircraft grades, 2024-T3 and 6061-T6 can be rolled and shipped with no issue. However, 5052 and 3003 does not return flat very well once it has been rolled. I would suggest finding someone with a trailer that could handle that size of aluminum. You can order aircraft grades at various venders online but the cost will be much higher than you quoted.
Scott
ssutton
Postby eggsalad » Mon Jul 07, 2014 3:00 pm
ssutton wrote:Only certain grades of aluminum can be rolled and naturally return to the flat state. Aircraft grades, 2024-T3 and 6061-T6 can be rolled and shipped with no issue. However, 5052 and 3003 does not return flat very well once it has been rolled. I would suggest finding someone with a trailer that could handle that size of aluminum. You can order aircraft grades at various venders online but the cost will be much higher than you quoted.
Scott
Yeah, all the thin stuff available locally is 5052. Rats. And you're right. for what online shipping should cost me, I could go rent a U-haul van and get it home cheaper. Grrr.
eggsalad
Postby dguff » Mon Jul 07, 2014 4:38 pm
I have transported .032 and .040 4' by 10' sheets rolled up as you describe several times for teardrops. Never had a problem with it taking some kind of a set. Used it on both the top and sidewalls and it lies flat.
Jerome
Jerome
2008 Guffman
dguff
Images: 69
Postby eggsalad » Mon Aug 04, 2014 8:14 pm
sometimes people don't follow up on their threads... but I will.
Not only did the 4x10 sheet of .025 roll up just swell, the guys at Curtis Steel rolled it up for me like it's something they do all the time. They even held the roll with some bailing wire, so it wouldn't unroll.
So there you go.
eggsalad
Postby citylights » Mon Aug 04, 2014 10:16 pm
eggsalad wrote:sometimes people don't follow up on their threads... but I will.
So there you go.
Curtis is great. I bought all my aluminum skin from them and most of my trim.
citylights
Postby bc toys » Tue Aug 05, 2014 6:56 am
Sorry egg I didn't hear from you and thought you must of found a way to get it home
bc toys
Images: 42
