I built my TD for Winter camping. Very easy to heat and comfortable even when it's very cold outside. A problem I've noticed with winter camping is that when it's really could out, especially below O, I tend to pick up frost and condensation around my metal doors and window. This really becomes a problem in cold weather when the foam mattress freezes to the TD Walls near the floor where my little electric heater can't heat the wall due to the mattress being in contact with the wall. I've noticed some discoloration of my interior wood siding below the door. It's got Polyurethene on it but apparently this isn't enough to keep the moisture from the door and window metal surfaces from entering my interior siding which is only made out of luan that has been polyurethaned. What I have just tried to allieviate this problem has been to cut my mattress into thirds so when it's in storage, the mattress parts can be stacked in the center of the TD, so that air can get to the walls where the mattress had prevented air circulation. Does anybody else have any ideas?
Art
