I have not come that close to a bear but I have been told by others who camp where bears are that load noises make them run for the hills. clanking of pots and pans, trash can tops, I would bring my triangle lunch bell which is loud and harsh. If brought a gun I would shoot it up in the air. I am not a good shot and would miss its eye or mouth. Bears have been hit by cars and walked off into the woods while the cars had to be towed away. They can out run you and out climb you. They say it is best to stand your ground and look as big as you can. Their pray is something that runs away.
quote from one site:
http://www.centerforwildlifeinformation ... nters.htmlIf contact is made, or about to be made, drop to the ground and play dead. Lay on your stomach, clasp your hands behind your neck, and use your elbows and toes to avoid being rolled over. If the bear does roll you over, keep rolling until you land back on your stomach. Remain still and try not to struggle or scream. A defensive bear will stop attacking once it feels the threat has been removed. Do not move until you are absolutely sure the bear has left the area.
http://www.gov.mb.ca/conservation/wildl ... unters.pdfanother site said
First, avoid bear contact by walking loudly, singing, talking, using bells on your pack. If you encounter a bear, the best thing to do is to slowly back away from the animal while making soft, non-threatening noises- "Nice bear, good bear." Do not make eye contact with the animal, do not turn and run. If a bear charges you, you have little choice but to protect yourself by dropping into a curled fetal position. Put your arms over your head and roll up as tight as possible. Bears will often bluff-charge and stop before actually making contact with you, but if they are set on attack, this totally submissive posture often deflects the attack. A bear almost never wants to eat you, and usually doesn't want to kill you. He is most interested in neutralizing the threat he perceives in you by making sure you are down, immobile, and harmless. Most people who are attacked by bears (even grizzlies) survive.
this one talks about pepper spray # 8 but read it all.
http://www.wikihow.com/Survive-a-Bear-AttackRon
