Hi guys!
It's getting closer and closer to when I expect to start my build. I think I've decided on minimum size and body style. One thing that I keep coming back to is the A/C system.
Now, I know that many people just wire up a 5,000 BTU Frigidaire wall unit and call it good. That's sounds like the easiest way to go for me, but I keep having thoughts about power usage. My intended purpose may not allow me to plug in and hook up the TD to AC power. Using an inverter off of batter power seems like it would drain the battery all too quickly.
So I'm thinking about some purely 12v cooling alternatives. I've seen many portable swamp coolers that use coleman or igloo style coolers combined with DC fans to create the cool, but that's only good for a few hours too, up until when the ice needs to be replaced.
I have an idea for creating a closed-system cooler, using condenser and evaporation coils, 12v fans and 12v submersible fountain pumps. I will have to do some extensive testing on that last option, so I was thinking if something similar has already been done.
What I've found is that there are numerous electric, portable coolers on the market. They typically plug into the car's cigarette lighter for power.
http://www.walmart.com/ip/Coleman-40-Qu ... r/21156022I'm wondering if one of the coolers can be modified like the other swap coolers and be used in a similar fashion. Has anybody tried such a thing? Is the cooling power good enough? Is the battery drain low enough that it could keep the cooler going all night?
Thoughts?
