I built my first TD in 2006 following the Generic Benroy plans. 3/4 ply on a Red Trailer extended to 5 x 10. Skinned in AL, and loaded to camp, it weighs in at 1,410 lbs. Other than the single bar tongue breaking in Arizona 80 miles from the nearest welding shop, I have had no problems. Built like a tank, acceptable weight, and pulls nicely behind my Honda Ridgeline.
I'm now looking at trailer number two. I have a 75" x 142" pop up frame on which I plan to build using a Cabin Car or Campster 12 profile. Either one will be skinned in AL, I enjoy building but I hate maintenance. As it will be a larger camper I am looking to save weigh where I can and still stay under 2,000 lbs. I am considering two options for the walls.
1. Build the walls with 1/2 ply. Is 1/2 ply is strong enough for a camper this size?
2. Frame the walls out of 1x2's, insulate and skin in 1/4 ply. This would not save weight over option 1 but should be warmer. Would I need the exterior 1/4 if I am skinning in AL? I know the commercial campers have nothing but the AL skin and that again would save weight.
Or is there an option 3? I looked at the way Grant makes his walls for the Campster 12, cutting out sections of 3/4 ply and filling with insulation, but this looks to be quite labor intensive.
What are your thoughts and suggestions?
As always, thanks in advance for your help.
Jim
