The Vetsport extreme SIPS microcamper
Postby Mobile Room » Sun Nov 16, 2014 1:05 pm
Hi to all
I'm looking to build my first tear drop and found this on YouTube, it's called the Vetsport Extreme SIPS Micro-camper. I like this as it has good insulation for cold weather camping, says it will fit on the 4 x 8 trailer frame and looks easy to build. anyone know any thing about this design? I found this on http://www.simplesolarhomesteading.com or go to you-tube and type in Vetsport, it will pop up to show the page. :thinking:
Mobile Room
Re: The Vetsport extreme SIPS microcamper
Postby DrCrash » Sun Nov 16, 2014 3:03 pm
Welcome and befor you buy some one elses plans, did you know these are FREE.
http://www.angib.pwp.blueyonder.co.uk/t ... tear00.htm
and here is the free one mike did
http://www.mikenchell.com/images/GenericBenroyPlans.pdf
DrCrash
Images: 51
Postby tony.latham » Sun Nov 16, 2014 3:04 pm
Mobile Room wrote:Hi to all
I'm suspicious of anyone selling trailer plans that do not have photographs of the finished product. I don't see any on their webpage nor on the Youtube video. Perhaps I just can't find a photograph or build log. I'm guessing he's drawn up the plans and has not built a prototype.
His mentioning 4" thick walls for a micro camper? Goof grief, that may vie for the record for a teardrop-like trailer (and it's cut the interior space down by 8" which is huge in a 4-wide). Most on this forum would call that gross overkill. 3/4" of insulation in a micro trailer is plenty. (I'm guessing it has to do with his construction method that isn't outlined on his page) The other issue I have with his plan is the single door. Two people in that trailer with one door is not social nirvana –plus that one sliding window is not enough ventilation. I see he's got a vent on top but you really need to move air in a tiny trailer.
The best thing I ever did (three teardrops ago) was purchase a copy of Steve Fredrick's teardrop Shop Manual. You can find a copy of it here: http://www.campingclassics.com/shopman05.html It's about 250 pages filled with photographs (not sketch diagrams) and how-to discussion. His hatch building method is straight-foreword and makes for a well sealed hatch.
But build! :thumbsup: :beer:
Postby Vedette » Sun Nov 16, 2014 3:25 pm
Great Advice and information Tony! :thumbsup:
Good roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby JuneBug » Sun Nov 16, 2014 8:37 pm
Also really like this little standy from the same Web site.
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
Postby grant whipp » Sun Nov 16, 2014 11:25 pm
There used to be a commercial teardrop builder in New Mexico that built all their trailers out of SIPs ... walls, floor, ceiling/roof, and hatch ... 1-1/2" thick ... HappiTrails Teardrops. He built a few with aluminum skin, but most used Filon on the outside, birch paneling on the inside. They were actually pretty rugged trailers, but fell a bit short on the fit & finish. As a personal project, where you have the time to research and figure out all the correct ways to make everything fit and look good too, I think the process has merit ... however, as HTT found out, trying to make them commercially and make a profit (why else would you do it commercially ... :thinking: ...?) is quite another thing. The panels have their limitations, especially where teardrop construction is concerned, but if you can work with or around those limitations, a decent product can be acheived ... :thumbsup: ...!
However you choose, good luck! And, of course, Welcome!
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby Vedette » Sun Nov 16, 2014 11:50 pm
What are SIPS?
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby GPW » Mon Nov 17, 2014 7:23 am
Structural Insulated Panels (SIP) .... If you want thick walls with Lots of Insulation you need to go to the Foamie' Section ... 8)
Postby bobhenry » Mon Nov 17, 2014 7:50 am
Vedette wrote:What are SIPS?
Brian
"STRUCTURAL INSULATED PANELS"
We just received in two semi loads of this......
http://www.huberwood.com/zipsystem/thermal
An oriented strand board sandwich with fiberglass faces and a center core of beaded Styrofoam.
This has my brain pan churning. I am getting ready to start on a tiny trailer house boat on a pontoon frame and this will more than likely be the side wall material of choice.
Postby Vedette » Mon Nov 17, 2014 10:41 am
Wow! Who would have thought? :oops:
Guess I am out of touch with construction methods of the day.
My brain is still working on Aero stuff & Dirty Air so I can faster with less drag??? :R
Thanks guys!
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
