rand_98201 wrote:[url][/url]http://i759.photobucket.com/albums/xx238/sumo63/2013-03-10_17-32-27_142_zpsecd9d00d.jpg
I was picturing something like this
Gage wrote:rand_98201 wrote:[url][/url]http://i759.photobucket.com/albums/xx238/sumo63/2013-03-10_17-32-27_142_zpsecd9d00d.jpg
First off you should have used [ img ][ /img ] not [url][/url]
Same concept just different end results.Go for it.
drhill wrote:you might want to consider a movable axle design as the weight will vary allot with the loads you haul. I welded my spring mounts to 2" angle and then bolted those to the frame. It can be fairly easily moved 4" or 8" forward or back of the "normal" mounting position. "normal" seems to be 60% of the distance back on a cargo deck. Once I mounted a tongue box and bike rack, I ended up moving the axle 8" forward. (the fenders are also mounted to the 2" angles)
