seth.dromgoole wrote:2) Is it possible/safe to build a 5x10 on a 5x8 trailer and using 2x4 build hang the frame either 2' off of the rear or 1' both front and back? Seems like this would add significant weight, which defeats the whole purpose of a TD
seth.dromgoole wrote:Thank you all for the great information. I've done a lot more research since my original post and feel much better about my first build. I think I'll build a 5'x10' on either a 5'x8' or 4'x8' frame depending on what I find for deals. I plan to do sandwich construction for the walls. Couple of follow-ups:
1) I'm in Utah and do a lot of BLM camping where I like to stay away from crowds. Most roads are well graded, but do have the occasion potholes and washes. Will 12" wheels work for me, or should I try to find 13" or larger?
2) Seems like trailers have a pretty standard axel rating of around 1800 lbs, is this adequate? I hope so, as the whole point of this for me is a lightweight trailer. Just got rid of a heavy pop-up as I didn't enjoy towing it 5 hrs to the desert.
Last thing I need to figure out is a bunk system for my kiddo, but I've seen lots of posts out there on this. A cold beer in my teardrop seems so far away!
Seth
