Sway
Sway
Postby mrwall1 » Fri Mar 20, 2015 8:43 pm
We went on a couple of couple hour trips last year even down I-5 and never noticed any sway but today we took off from western Washington over to Yakima valley and if we crept above 60 the trailer really started swaying... The only thing different we did was switched our hitch with the ball a little higher so trailer rides more level... Any ideas I switched back the hitch lower for the drive home Monday.....
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Re: Sway
Postby KennethW » Fri Mar 20, 2015 9:11 pm
By moving the hitch up ,You are also moving weight to the back. I think if you move some weight to the front of the trailer or remove weight from the galley. Will help with the swaying. :thinking:
KennethW
Images: 82
Re: Sway
Postby MtnDon » Fri Mar 20, 2015 9:20 pm
KennethW is on track. What is the percentage of total weight on the hitch ball? You need more weight on the tongue/ball.
MtnDon
Images: 24
Re: Sway
Postby mrwall1 » Fri Mar 20, 2015 10:38 pm
Thanks guys!! I will do that also ... Move more stuff to the front page f trailer
Mike
mrwall1
Re: Sway
Postby logman7777 » Fri Mar 20, 2015 10:56 pm
I have to agree with the other posts..
Towed my landscaping trailer with 4' sides out to Indiana (640 miles) with absolutely no sway and at capacity. On the way home it was empty and the sway was noticeable all the way back over 60 mph.
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Re: Sway
Postby Socal Tom » Sun Mar 22, 2015 8:37 am
Low tongue weight causes trailer sway.
Socal Tom
Re: Sway
Postby logman7777 » Sun Mar 22, 2015 4:31 pm
Yup Yup Tom.. :D
logman7777
Re: Sway
Postby mrwall1 » Fri Mar 27, 2015 3:23 pm
My Deep cycle battery is bad, so I took it out and put my car jump starter in its place in the tongue box, so the actual tongue weight was only 90 pounds.... So on the way back, I switched the hitch back to lower.... put the 24 bottles of wine the wife bought to the front wall in the trailer... and a few other heavier items forward.... the trailer only swayed a couple of times on the way back... but seemed like windy areas...
thanks for all the help!
mike
Mike
mrwall1
