Thoughts after 1st long trip.
Postby daveesl77 » Sun Jul 05, 2015 6:41 pm
To begin with, other than a problem with a hub, it was great. Wife absolutely loves the camper, like really, really loves it. I'm pretty happy with it too, but see things I need/want to change.
1) Galley - my slide out/rotate galley worked great and folks that saw it loved it. It set up fast and was stable. Main problems were that when I built it I made it just too tall and have very little clearance between the top of the cabinets and the bottom of the bed frame. I also made it out of 3/4" ply and it is way heavier than needed. So, I'm going to rebuild making it shorter and maybe a bit wider on the individual boxes. Haven't fully decided on the new material, but I'm leaning to using 3/4 ply base with aluminum framing and then making the sides from thin ply/foam/PMF laminations. I'll play around with some designs. The flip out sink and rotating cabinet were great!
Definitely will use the original roller bearing idea I had for movement. While it slid in and out fairly easily, I'd like it to be more smooth. Rotational system works, but I can make it better. Using the camlok camera tripod legs worked like a charm, but now I want to make them to where they rotate and don't have to be removed. In addition, I had run out of time so I did not run my water hoses internal on the cabinets, so that changes. Also need to make my aluminum folding screens for the stove to cut down on wind blasts.
2) Absolutely have to get the aluminum skin on the lower front to protect against road grime and stuff.
3) By lowering cabinet height, I will go back to my original idea of making the front 18" of my bed frame moveable. That'll allow it to drop down a couple of inches for use as a settee then raise easy as a bed.
4) Got to get my shelf rails installed, was a real pain to always have to take stuff down and put it up when moving.
5) Finish the duct system and do the AC box build. It worked great as a temp unit by putting it in one of the doors and having a cut out for it, but I don't want it stuck outside the camper, after all that's why I build the ducting.
6) Add in a few more 12v outlets and finish up the LEDs. I think I'm also going to add in a reverse light. I realized when backing in one night, since the trailer is narrower than the truck, I have a really hard time seeing where it ends and what is behind me. I have a 7 way plug and reverse is already wired to the plug, so I only need to run a wire and light down the trailer wiring tube.
7) Build a slide out shelf unit for my laptop. With the bed and existing shelf unit, while I had lots of room, it was a pain to have to lean way over to type on the computer.
8 Add in some kind of holder for the plexi inserts for the wiley windows. I can see where it can become helpful in the future.
9) Replace the stupid "converter" charger with a true automatic charger. I got a nice, big RV converter box from a salvage yard for $10 during the build, mainly for the circuit breakers and fuse block. While the converter does charge, it is a massive heat generator and is one of those idiot systems so it doesn't stop. I figure I'll just pull the charging guts out and replace with one of my automatics, while keeping the breakers and fuses. Save weight and heat.
I LOVE this little trailer and can see it going on a lot of trips! Next planned is a week in the Keys in October, then the Gathering in November and then wifey wants to head back out west in April. Probably some short trips in between.
dave
8) Finish up all the trim.
daveesl77
Images: 273
Re: Thoughts after 1st long trip.
Postby tony.latham » Sun Jul 05, 2015 6:55 pm
:beer:
Postby dales133 » Sun Jul 05, 2015 8:40 pm
Sounds like you nailed it.all your proposed changes are realy just refinements on great ideas you'd already come up with but just with a bit of time to think how to fine tune them.
Congrads
dales133
Postby Shadow Catcher » Sun Jul 05, 2015 8:52 pm
Progressive Dynamics makes a replacement power unit which may well slip right into your power center.
http://www.progressivedyn.com/pd4600_converter_replacement.html
Postby noseoil » Sun Jul 05, 2015 10:08 pm
Dave, sounds like a great trip & plenty of "new" stuff to do on the build for now. Sounds like the 3/4" ply was too much of a good thing. Could you get away with a 1/2" bottom panel & some 1/8" & 1/4" materials instead?
If you take the southern route in April (I-10) please look me up.
137905
noseoil
Images: 670
Postby deleted » Mon Jul 06, 2015 8:10 am
Great update! Wonderful to hear you both love the trailer so much. :thumbsup:
deleted
Images: 85
Postby Vedette » Mon Jul 06, 2015 10:17 am
Glad to here you and the wife both enjoy the camping and lifestyle that comes with Teardrop Trailer camping. :applause:
Enjoy, enjoy, enjoy! :wine:
As per the above recommendation for Progressive Dynamics Converter :thumbsup: :thumbsup: :thumbsup:
We all tend to build a little too heavy the first time around??????
Your improvements sound good, but remember they are never really finished. There are always so many cool ideas out there??? :thinking:
Good Roads
Brian & Sandi
How about a trip to the PNW in your future??
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby daveesl77 » Tue Jul 07, 2015 5:31 pm
So here are some photos
Sherando Lake, NF, Virginia. An overnight that ended up taking us over an hour just to pull out. Lots of folks wanting to see the Fritter
133790133791133792
PA
133793133794133795
Max Beagle's special rear seat
133796
Overpriced, crappy state park in Maryland
133797133798133799133800
Terrifying truckers in Virginia(?)
133801133802133803133805
Paynes Creek, Lake Hartwell, GA Corps of Engineers
133806133807133808133812
133809133810133811
Brilliant beggar fox
133813133814133815133816
dave
daveesl77
Images: 273
