Anyone have a good (cheap) source for stainless steel
Postby Hennesseystealth » Tue Aug 25, 2015 5:00 pm
I am going to cover my galley counter top with stainless steel. I am trying to find a piece of 316L at 24" x 60". All I can find from my local suppliers is 48x120 for over $100. I just hate to waste money and good material. I am in NorCal.
Thanks
Hennesseystealth
Images: 16
Re: Anyone have a good (cheap) source for stainless steel
Postby shootr » Tue Aug 25, 2015 6:36 pm
Does it have to be 316? That's pretty heavy duty in the corrosion resistance category, food uses are usually OK with 304.
Might be less expensive, but I don't know in sheeting.
shootr
Postby Hennesseystealth » Tue Aug 25, 2015 6:54 pm
304 is fine too but the prices I found weren't much different, so I was opting for the better product.
Hennesseystealth
Images: 16
Postby Redneck Teepee » Tue Aug 25, 2015 9:12 pm
A local Sheet Metal shop should be able to help you with a drop or rem sitting in their rack and only charge you for the actual size and maybe some shear/forming time if needed. :thumbsup:
Redneck Teepee
Images: 21
Postby Hennesseystealth » Tue Aug 25, 2015 9:16 pm
Good idea.
Hennesseystealth
Images: 16
Postby Jiminsav » Sat Sep 05, 2015 5:04 pm
If you have a McElroy Metal place close by, try them..i got 4x10 sheets of aluminum there at a good price.
Jim in Savannah
Jiminsav
Images: 40
Postby ctstaas » Sat Sep 05, 2015 6:36 pm
IMHO, Stainless steel is around 3 x $ of mild steel but you get what you pay for. True Fact-Food grade SS is not magnetizable. Imagine having metal slivers magnetized to your counter top.
Enjoy, Chris
ctstaas
Postby Hennesseystealth » Sat Sep 05, 2015 8:24 pm
The reason for stainless is it is much harder to cut into with a knife. No McElroys out here in CA as far as I can tell. And yes, I definitely want Austenite.
Hennesseystealth
Images: 16
Postby cheri832 » Mon Sep 07, 2015 2:39 pm
Try a salvage restaurant supply. I redid kitchen counters in stainless when I lived in TX and I was picking up beautiful rolled front pieces for $30-$50. Just an option. :D
Cheri
cheri832
Images: 15
Postby Hennesseystealth » Tue Sep 08, 2015 6:27 pm
cheri832 wrote:Try a salvage restaurant supply. I redid kitchen counters in stainless when I lived in TX and I was picking up beautiful rolled front pieces for $30-$50. Just an option. :D
Found a local company that makes industrial fryers and cookers in stainless and seeing if they would sell a small piece or direct me to a supplier that will. I am hoping they have scrap in their process and will be willing to let it go.
Hennesseystealth
Images: 16
Postby Hennesseystealth » Wed Sep 09, 2015 8:46 pm
My aluminum supplier now carries 4'x8' 24 gauge in 304 with a #4 finish for only $66. While I still end up with waste, it isn't as bad as the larger sheet I was originally quoted.
Hennesseystealth
Images: 16
Postby Esteban » Wed Sep 09, 2015 9:02 pm
Hennesseystealth wrote:My aluminum supplier now carries 4'x8' 24 gauge in 304 with a #4 finish for only $66. While I still end up with waste, it isn't as bad as the larger sheet I was originally quoted.
How much does a square foot of 24 gauge stainless steel weigh? if it's not too heavy I may use it too.
Google is my friend. Found out it weighs 1.008 pounds per square foot.
engineeringtoolbox.com Gauge and Weight Chart
I would need about 8 sq.ft. for my galley's 18" x 62"counter top. That would weigh about 8 lbs. Good if all the details could come together. Would need a source for the stainless steel and someone to cut and bend it to the size and shape needed.
Steve - SLO, CA
Esteban
Images: 15
Postby Hennesseystealth » Wed Sep 09, 2015 9:12 pm
I thought about the next build...if that ever happens. Given the issues I have with finger prints and surface contaminants that stick to mill finish aluminum, I was thinking about 304 as a substitute. It is about 2x the price, but also 2-3X the weight, which is a bigger deal.
Hennesseystealth
Images: 16
