Cooler air circulation
Postby Stainless » Sat Apr 16, 2016 11:45 pm
I've built a 1.3 cubic foot drawer-style cooler for my converted cargo trailer out of wood and rigid insulation. There's a tray for a roughly two or three pound block of ice in the bottom of the cooler.
The cooler has power for a light inside, and I'm wondering if a little computer fan as well would be beneficial. I haven't been able to find any data to determine if the additional half-amp draw on my precious battery supply (I am a boondocker) for air circulation would be worth the energy cost.
Does anyone have any thoughts?
Stainless
Re: Cooler air circulation
Postby Vedette » Sun Apr 17, 2016 12:16 am
I didn't do a ton of math....but just went by principal, and built at an external air conditioner that worked like a swamp cooler to pump cool air (filtered) into our teardrop????? In principal....it worked perfectly! But, in 108 degree temps in Bullhead City......it failed dismally! The 20 lbs of ice that was supposed to last through the night, worded to cool off the teardrop in about 15 minutes before we retired to bed. :roll:
but , within an hour, the ice was gone :oops: and the air lowing from the fan was hot! :cry:
Not as thought!
GoodRroads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Stainless » Sun Apr 17, 2016 1:24 am
Vedette wrote:I didn't do a ton of math....but just went by principal, and built at an external air conditioner that worked like a swamp cooler to pump cool air (filtered) into our teardrop????? In principal....it worked perfectly! But, in 108 degree temps in Bullhead City......it failed dismally! The 20 lbs of ice that was supposed to last through the night, worded to cool off the teardrop in about 15 minutes before we retired to bed. :roll:
Not as thought!
GoodRroads
Brian & Sandi
My mistake, I should have been more clear. This is a food containing cooler box that is very well sealed, to a point where I can feel the air rush when I close the horizontally hinged lid. The foam box is two inches thick everywhere. I am wondering if it's worth the energy consumption to have a fan inside to circulate the cool air from the ice around the food.
Stainless
Postby Vedette » Sun Apr 17, 2016 2:13 am
oops? :oops:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby mustangcats » Sun Apr 17, 2016 9:01 am
You can buy a small refrigerator fan that uses its own battery power. http://www.amazon.com/Camco-44123-Fridg ... B0006IX7TW
mustangcats
Images: 18
Postby JaggedEdges » Tue Apr 19, 2016 7:15 pm
Be aware though that the fan doesn't "consume" electricity, so much as turn it into low grade heat, so you're effectively installing a 5 watt heater.
Ice box designs I've seen in classic teardrop plans, have the ice block on top and let convection do the work.
Jack of all trades, Doctor of rocket surgery and fellow of the noble college of shadetree meddlers. "in argentum tenax vinculum speramus"
JaggedEdges
