My take on making coffee in camp and the end solution.
Postby desertmoose » Mon Apr 18, 2016 10:39 pm
Over the years, we have tried several ways of making coffee in camp (without a generator or a 120V supply). Percolated coffee was the standard when I was growing up, so I asked for a percolator for Christmas. Youngest boy and his family got me one of those blue enamalware campfire pots. The one that's real wide at the base. We tried it for quite a while, but never was happy with the taste. I think it's due to the percolator pump plate being so small compared to the bottom of the pot. Most of the boil misses the plate and can't help pump the water up to the grounds. By the time the coffee finally got dark enough, it had a nasty burned taste. Varying the temperature didn't change things other than the time to perk it.
Cowboy coffee left it chewier than we liked, even with the trick of a dash of cold water to settle the grounds.
A french press worked ok, but was slow and took a lot of water to clean up. That's a concern when you're mostly boondocking in the desert or mountains without a handy tap to get water from.
Coffee bags and instant/ freeze dried didn't have the taste we wanted. (putting it politely).
I tried running a small coffee maker off the solar batteries, but the power used was more than I have available. especially with multiple pots.
Next we tried a collapsible drip basket that sat on top of the coffee mug. It got closer, the taste was good, but took a long time to dribble the water in so it didn't overflow, and also got cold pretty quick from being exposed while dinking around with it. Also... we had to clean up more than once when the basket got knocked off the mug.
Remembering when I was a kid, the waitresses at the diner used to prepare a basket of grounds, and then dump a pot of hot water into the top of the coffee maker and walk away while it trickled into the grounds gave me a target.
Here's what I came up with,
First, you have the whole shebang in an insulated carry bag that Kat made for me.
Here's the parts laid out. A thermos, the collapsible filter holder, a water pot, and a stand to support the whole thing.
The first step is to screw the legs into the lower ring and set it over the thermos.
Next the filter holder sets into the hole in the lower plate.
The uprights plug in to hold the upper ring in position.
Add the filter and grounds. Clothespins keep the filter from folding over.
Another shot of this stage.
Next, heat the water, I put the water pot on to preheat it while the water heats.
Once the water boils, set the water pot in place.
Here's a closeup of the drip hole in the water pot. You want it to drip fast enough so the water/ coffee stays hot, but don't want it to overflow the filter basket.
We add an inverted bowl to the top of the water pot after filling it with boiling water. This keeps the cover out of the water.
Finally, cover the whole thing with the carry bag. Now it's clear why it is insulated, it keeps everything hot while brewing.
Now, you can go ahead and make breakfast, or whatever. The coffee brews, then drops into the thermos. It will stay hot and ready to drink for a long time while you are busy otherwise.
A few notes on development. I found the stainless pot at a garage sale. I'm looking for another similar one since I want to make another one of these for our other trailer,
The legs now screw into the lower ring. The first proto I made had then plugging in like the upper ring support posts... stood ok, but when you tried to move it, one leg always fell off. Threading them in solved that problem.
The hole in the water pot started out at 1/16". After a few tries, I opened it up to 5/64". this proved to be perfect. Water runs thru fast, but doesn't overflow the filter basket.
I made the support rings on my 3D printer, but carefully cutting them out of plywood would work just as well.
Bottoms up!!
Sam
(BTW, we call this the alien coffeemaker because it reminded us of the alien machines in "The War of the Worlds")
desertmoose
Images: 98
Re: My take on making coffee in camp and the end solution.
Postby Sierraguy » Mon Apr 18, 2016 11:26 pm
Lately I've settled on this hybrid system for camping. An old plastic filter cone atop a thermal insulated press pot. After the coffee drips down I put the press pot top on to keep it hot.
Sierraguy
Postby kudzu » Tue Apr 19, 2016 8:33 am
Very creative solution. :thumbsup: It's a set up that could brew some great coffee. It reminds me of a homemade version of what I use at home. This picture is a duplicate of what I inherited from my grandmother. I use the glass globe of this 50+ year old coffee maker, as it's the best brewing drip coffee maker I've ever had. Though it took some searching, I found a thermal carafe that's a good fit for it. That gives me the convenience of the original set up but keeps the coffee at a good drinking temp:
Not going to take a glass, family heirloom camping though. So I opt for brewing in a moka pot. It is also a 3 layer system & almost a hybrid of a percolator & a drip brewer. It heats the water in the bottom reservoir & forces it up through the coffee in the filter basket one level up & then finally it goes up a central tube, similar to a percolator, into the top reservoir. At that point you take the pot off the heat & I pour it into a big thermal mug.
It takes about the same time as boiling water & water for cleaning up is relatively comparable to drip coffee. While somewhat less labor intensive to set up than your camp solution, I do have to remember to take it off the flame soon after it is done making coffee or I'll end up with the same effect as a carafe of coffee that sits on a warming plate. Coffee is a funny addiction. I've probably put more time & effort into trying out different coffee making methods for camping than I have on cooking food. :lol:
kudzu
Images: 16
Postby Redneck Teepee » Tue Apr 19, 2016 9:41 am
No need for all this, my recipe for good coffee is simply...... a good Stainless Steel percolator, clean fresh or bottled water and most important is the proper roast, grind and amount to fit your taste buds. Perk for 5 minutes let it stand for 1 minute pour and enjoy!
Redneck Teepee
Images: 21
Postby JaggedEdges » Tue Apr 19, 2016 1:44 pm
Yes, coffee is the sticking point here with going "non-electrical", these days you don't need much battery to give you LED lighting for a week, most gadgets are low power and can be charged or ran off 12V. Cutting the cord greatly increases site availability at a given park, and also greatly increases availability of other places to camp. I don't mean parks have a huge number of non-electric, might only be a third of the whole, but electrical are booked up months in advance, and you've got your pick of the non-electric even just a week ahead.
Anyway, nice coffee kit, looks good for when there's a fresh breeze, had an old stove couldn't even boil water on it's small burner "off season" when there was any kind of breeze, say when it was 60 degrees or less of a morning, so know how that affects keeping things hot.
What we have "tried out" but not yet relied upon is a 60s or 70s vintage drip funnel and pot, made coffee okay. It's a huge funnel, put the largest size cone filter in it and you only have to pour water twice to do the pot. However, the plastic in the funnel seems to be showing signs of age, and the glass carafe is somewhat thin, making us a bit nervous about it's survivability. Also would probably have that cooling problem in certain conditions.
Just aquired is a Mirro brand percolator, that looks like a decent piece. I can use it on the coleman stove, or a propane stove. Need to do some test runs before we camp though. What I'm hoping to do though is make a coffee kit based around it, that has a wind screen made out of coffee can, and a burner from a fondue kit, so I have a coffee setup that is portable, self contained-ish, can be brought on picnics, used on the tailgate as it were, that can be used with precautions indoors, well not in typical height small TD maybe, but under your awning. The idea being, roll out of bed, spark up the coffee, no fumble.
Somewhere though, I have an insulated pot, no hotplate, B&D 4 cupper, that I have been meaning to find out the wattage of. I have got this wonderful little power box that can run 400W for 2 hours, well, it's not so so little, but portable. Been wondering if that machine or a single cupper to travel mug type, could be run off that power box. I know 12V single cuppers are quite useless having maybe a 75 watt max.
I've seen those coleman pots, I stalk the shelves where they live at various stores hoping for a drastic markdown, LOL.
It does seem to me some kind of DIY candle, burner or even direct solar drip maker should be possible. I've got a dud machine in the basement I should tear apart to learn it's secrets. I think it's just making the small, free moving valves that enable operation as a thermo-siphon is the trickiest bit.
Jack of all trades, Doctor of rocket surgery and fellow of the noble college of shadetree meddlers. "in argentum tenax vinculum speramus"
JaggedEdges
Postby rmclarke » Tue Apr 19, 2016 3:11 pm
Nice McGyver there, Desertmoose!
I've been using a Melitta pour over gizmo when we camp, but recently I found this little goodie and I couldn't resist.
It was $12 bucks @ Amz. It does Kcups and comes with a 'fill-your-own' filter if you want. At home, water is heated in the micro; but camping, just use hot water from the camp fire pot, propane stove, whatever. I takes about three or four presses on the plunger and does require a bit of muscle, but all in all, I like it. Also does Kcup tea, hot chocolate, etc.
I don't use Kcups at home, but for camping, it's a nice splurge.
My $1 worth (I know...inflation)
R.
rmclarke
Images: 231
Postby JaggedEdges » Tue Apr 19, 2016 3:55 pm
Now that is a pretty neat piece of kit. I was thinking as I came back into thread, whether one could jam a keurig refillable in the end of some pex hot water pipe and whether it would run through.
Only quibble with that though is that as with many single cup methods you tend to use 50-100% more coffee per cup.
JaggedEdges
Postby wagondude » Wed Apr 20, 2016 7:48 pm
Another option is the cold brew technique. Put ground coffee in a jar, fill with water, put on the lid and stick it in the fridge for a week or so. What you get is a strong concentrated coffee base that you can then put a little in your cup and top off with hot water to make a full cup. It takes a little trial and error to get it the way you like, but if you camp with folks that don't like coffee, your pot of hot water can be used for coffee, tea or hot chocolate as well as your oatmeal.
A lot of hotels are using frozen coffee concentrate cubes to make their big pots of coffee that are out with the continental breakfast.
Bill
101137
wagondude
Images: 35
Postby bamajoe » Thu Apr 21, 2016 1:51 pm
Could do this to..
Makita DCM500Z 18V LXT Lithium-Ion Cordless Coffee Maker https://www.amazon.com/dp/B010FZDG82/re ... gxb6HRXPBFImage
Sent from my iPhone6s using Tapatalk
bamajoe
Postby JaggedEdges » Thu Apr 21, 2016 7:12 pm
Two possibles turned up right under my nose this morning, went in the local branch of the place linked and found..
http://www.factorydirect.ca/Canada-Onta ... 04002381/0
French press always tastes too muddy to me though. Maybe I should get a coarser grind and try some again. Think I have a pot somewhere.
Then there was also this...
http://www.factorydirect.ca/Canada-Onta ... 55991021/0
Which claimed to only draw 300W, I think, the only place wattage was stated was on the Spanish side of the box. Anyway, 300W-ish inverters and power boxes are pretty common and among the cheapest.
Though I noticed another thing last night, while stranded at a relative's place, oddly, instant coffee and coffee whitener taste way better than instant coffee and milk/cream or real coffee and coffee whitener. Though not as good as real and real of course. I could quite easily put up with that combination myself, her indoors is a fresh black coffee freak though.
edit: seems best buy carries those better chef ones too http://www.bestbuy.com/site/better-chef ... Id=1613554
edit II: You know what, I had to try that again to check it wasn't a fluke, "emergency" instant coffee and whitener dug out, sipping it now and yah, for some reason it's as good as "indifferent" restaurant coffee, you know where they don't really care that much and buy a cheap grind, but at least make a fresh pot fairly frequently.
JaggedEdges
Postby greygoos » Thu Apr 21, 2016 8:21 pm
Liquid coffee concentrate is taking the food service industry by storm. I have seen it on Amazon for home use. It is easy and there is no waste. I have done many tastings through the years and it is right up there with all kinds of brewing equipment.
greygoos
Postby booyah » Fri Apr 22, 2016 6:52 am
French press has always been my go to.
Take some care with the grind, take your time on the push, and time the brew right and its some of the best coffee around.
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby JaggedEdges » Fri Apr 22, 2016 10:25 am
Any hints on what commercial grinds work well in french press?
JaggedEdges
Postby dales133 » Fri Apr 22, 2016 11:18 am
We use medium grind in coffe plungers here (french press)
dales133
Postby JaggedEdges » Sat Apr 23, 2016 3:32 pm
Just been playing with the fondue fuel burner, 5ml of fuel has it burning for around 2 mins 30 secs of "useful" flame, then it takes another 30 seconds or so to dwindle out. That 5ml provides around 75kJ of heat and you need 1kJ per pound of water per degree F to raise temp. So 10ml would just about boil 1 pound of 60ish F water in 5 mins. However, that's assuming total efficiency. 1 pound is close to a pint-ish. Think the percolator is a bit over 2 pints total capacity, assuming capacity is in 5 oz cups.... so in theory, need about 20ml of fuel to boil it in 10 mins.
However, I'm thinking the fondue pot stand I've got is a bit of a heatsink, nevermind the sinkiness of the perk itself and what it will waste in steam, so I'm thinking it would take more like 20 mins to brew up fully and 40ml of fuel. Though that's a bit pessimal. Maybe about half again as much, and 15 mins more on the mark going by the fuel/stove testing here.... http://adropofrain.net/2013/05/alcohol- ... -methanol/ assuming the fondue burner is at least as efficient as something cobbled together out of tin cans.
Though I'm kinda wondering if the fondue burner wouldn't work "better" on a perk pot than many other burners because it heats that spot in the middle right under the pipe. So wondering if you could have it boiling under there, while bulk of water/coffee is not boiling, probably cooling on the way up, but providing enough pressure to cycle it at lower than total boil point, meaning you don't get the overperked "burnt coffee" problem..... on a normal burner it heats pot from the edges. I'm kinda wondering how to effectively test the perk now it's potentially going to behave different on a regular stove burner. I was hoping to get the coffee amount and run time dialed in on a stove that didn't have other variables.
Also turns out the danged stand is about a quarter inch too big to go in a coffee can, need to recalibrate my eyeball. So something else for wind shield arrangement will have to be done. Found a slightly bigger danish cookie tin that could do for the base. I guess I need quite a hole for messing with the burner and slot for the handle, so I could use a slit open coffee can for the sides. Was looking at a way to have the pot sit off the stand a little on some silicone feet, stop heat transfer to stand, theoretically bulk of pot reaches max of 212 when silicone good for 450, however, the particular bits of silicone stuff and design of stand puts them in actual flame at the moment, which is ungood, since methanol flame can go to 3500ish. As I mentioned trying to go for a "coffee appliance" here that's all in one lump and can be carted on picnics also, and contained enough you can use it under canvas/tarp if it's pissing with rain... though I think I'd wanna have 4ft clear air over the top of it, and no chance of knocks so wouldn't use it in a TD sized TD, possible in a "crouchy" say 5ft high inside coach.... as long as you get your fuel handling down to a safe art and aren't going to splash it everywhere. Mind you, I guess I'd hang an oil lantern on a 2 ft chain and think it was fairly safe, maybe reconsider with experience when I see how much heat it seems to make in a smaller space. (Ventilate, ventilate, ventilate, I know someone gonna say it... )
Was in a regular store "Do you have any different grinds", point me to the espresso grinds, derp, then they tell me Folgers says it's suitable for all coffee makers, this is Canada for you though, not a wide choice in anything. I bet if I look under coffee specialists in yellow pages there will be 30 Tim Hortons and 2 Starbucks. Yah, I've got some ideas of where to try, just happened to be there.
JaggedEdges
