Harbor freight trailer info ?
Postby rustytoolss » Tue Jun 21, 2016 9:01 pm
I had saved this somewhere but can't find it. Questions about Harbor Freight 4x8 trailers. What's the difference's between The 1190lbs heavy duty trailer & the 1720lbs super duty trailer ? When the trailer is sitting level/ What's the distance from the ground to the bed mount ?
Which trailer is most used for a max weight of 1000lbs (or is it just smarter to go with the super duty trailer ?)
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Harbor freight trailer info ?
Postby Woodbutcher » Tue Jun 21, 2016 9:33 pm
Buy the heavier duty one. The smaller one comes with 4 bolt rims, and smaller tires. I would never want to build up close to a trailers max. limit. Otherwise look into the Northern Tool trailer. It's 5' wide and comes with 12" rims. Someone just posted recently a coupon on that trailer.
Woodbutcher
Postby WizardOfOdds » Tue Jun 21, 2016 10:33 pm
HF has been selling more 4x8 models than you can shake a 20%-off coupon at! :?
For the most part I agree with buying the most expensive one, but do some homework before you buy: Call your local store and find out the EXACT SKU of the trailers they stock, then DOWNLOAD the manuals for the trailers they stock and read them with a lot of care:
What size wheels? Some have 8 inch wheels, the others have 12 inch, but some of their trailers with 12 inch wheels have only four holes. I would only settle for the 12 inch with 5 holes.
The last time I looked they sold 2 different high end 4x8 (SuperDuty) models (both for the same price), both of which fold (the older 1720# trailers did not fold). Seethis post,
http://www.tnttt.com/viewtopic.php?f=35&t=61898&p=1106726#p1106726.
One of the key differences was one had a round axle and the other had a C-channel axle. I prefer the round axle.
Finally, remember what you read on this site may not be for the same trailer you buy today. See my “Tail of Two Trailers” for a what I mean.
http://www.tnttt.com/viewtopic.php?f=35&t=61451&p=1105341#p1105341
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 43
Postby Graniterich » Tue Jun 21, 2016 10:55 pm
They don't take The twenty percent coupon on trailers anymore, YMMV
Graniterich
