Wiley widows, seals,screens ?
Postby rustytoolss » Tue Jul 05, 2016 3:02 pm
When you guys make Wiley windows , do you use some tape on foam weather stripping to stop water from seeping in (when closed) ? Also what about screens ?
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Wiley widows, seals,screens ?
Postby daveesl77 » Tue Jul 05, 2016 4:05 pm
The window design itself, if done right, keeps water out. With our trailer, we have 4. I leave them open (Florida) all the time, meaning that the plexi is left in the frame, but angled back so there is a 4" opening at the top to allow for air flow. Massive summer storms, the recent tropical storm, not a drop of water inside the camper. Towing last year through Virginia at 60 mph, in heavy rain, not a drop inside.
Make the base angled down and out. I sealed all interior portions of the window and wall with epoxy and then did angles down to the central drain line. The plexi is held back by the triangle shaped side holders. They force it closed or open. The screens are held to the inside of the window wall opening with hot glue, this allows me to remove them if necessary to clean or replace.
Here are the ones on the door before they were sealed
131592
Here is a wall one, right after it was mounted, showing kind of how they work. The interior is just being worked on in these shots. All the plexi can be removed to be fully open. The door ones have a cross bar as we can mount an O-2 12 volt fan in the window(s) if we want. We also have ducted ventilation at the front. We sprayed all of the plexi with the window frost paint, so we can allow light in, but still have privacy.
131430
131429
You can see the down angle on the bottom wood and the lower back piece of wood. These form the trough that keeps water out. All edges and corners are sealed with epoxy, then poly over.
The screens aren't mounted yet in any of these and the triangle lock piece aren't in place either. The triangles are just pieces of wood that match the angle of the window sides. you'll also notice that the plexi comes about 1" above the window opening, that is so when opened they are still above the opening top, so rain doesn't get in. I've had several sailboats in the past that had these type of windows. They work great.
Here is the finished product, with the temporary fan in the door.
138990
dave
daveesl77
Images: 273
Postby KennethW » Sat Jul 09, 2016 9:31 pm
I made my window to use two panels. A window panel and a screen panel. The screen panel has a hole with the screen glued on. So if you want you can remove both or any combination.
KennethW
Images: 82
Postby Ron Dickey » Sun Jul 10, 2016 4:29 pm
I too am about to build them.
viewtopic.php?f=2&t=51721
viewtopic.php?f=21&t=57192&start=15
I plan to make the screen be part of the outside window frame, between the door skin and the window frame I will put a screen. and plan to have the drip line below that frame.
I build a hollow door so on my outside cut will be lower and wider then my inside window cut. But there are some really good pictures in here showing the lower water leak line.
done by Rowerwet
rowerwet wrote:some sketches to help anyone interested understand the details
view cut in half
116351
view from inside looking out
116352
outside looking down and in
116353
outside looking in: make sure the inner lip is higher than the outer one, your drain holes may get plugged, but the gutter will still drain outward that way.
116354
top view
116355
lying under the window frame
116356
there is a trough at the bottom that runs at an angle and a whole at the front bottom that lets it out.
Mine will be a little different but the best way to do it is to make a model. simulate what you will do and find the flaws before you have to make a new door.
Ron :wine:
173882......173887
Ron Dickey
Images: 787
