Roof mount vent Height ?
Postby rustytoolss » Wed Oct 05, 2016 11:43 am
I'm working with a tight garage door clearance :NC . Can some of you chime in, on how tall your roof mounted vent is, from top of trailer-to of vent.
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Roof mount vent Height ?
Postby drhill » Wed Oct 05, 2016 1:35 pm
Just went out and measured mine for you and it is only 4-1/2" high, as long as I remember to close it.
It is the white RV roof vent from Canadian Tire
drhill
Images: 37
Postby Tomterrific » Wed Oct 05, 2016 2:24 pm
I laid a straight edge on top and measured 2 1/4" to the roof. It's the old style vent with metal top.
Good call on remembering to close it! :-)
T
Tomterrific
Postby rustytoolss » Wed Oct 05, 2016 6:03 pm
Tomterrific wrote:I laid a straight edge on top and measured 2 1/4" to the roof. It's the old style vent with metal top.
T
Might? have room for one of those ..if I could find one.. I'll know more in the future.
rustytoolss
Postby clip » Wed Oct 05, 2016 6:35 pm
I was trying to figure this same thing out today for a F-Fan, because of the same issue. Considered the usual tire pressure or even the extreme of popping off the brick mold trim etc if I was really close.
clip
Postby rustytoolss » Wed Oct 05, 2016 8:22 pm
I've removed the wheels and tires, to lower my overall height (helps a lot) . I can roll the frame on the spindle hubs. Once out of the garage I'll reinstall the wheels.
rustytoolss
Postby KennethW » Wed Oct 05, 2016 8:43 pm
On a HF trailer with the round axle you can install the axle over the spring and cut clearance in the mount, to lower the camper .
KennethW
Images: 82
Postby rustytoolss » Wed Oct 05, 2016 8:56 pm
My trailer has an old pop up frame, which has a torsion axle.
rustytoolss
Postby tony.latham » Wed Oct 05, 2016 10:56 pm
Scroll down to High and Low Profile Bases: http://rvvent.com/pictures.htm
