tony.latham wrote:My first teardrop was commercially built by Hunter. It had storage under the mattress. You'd had to lift up the mattress, lift the plywood piece that covered the storage and then rummage around with your third hand to find what you needed. I thought it was a pain.
There's probably a way to make it more accessible.
bobwhite215 wrote:Thanks for all the feedback everybody. I think I am going to skip the underfloor storage. In all likelihood we will be pulling the camper with a pickup most of the time, so it's probably just not needed. If I change my mind, I can always cut out a section of floor and add a box at any time.
Sent from my SM-T817V using Tapatalk
QueticoBill wrote:How low do you all go, as in ground clearance? Below the frame? Forgo insulation?
It sounds appealing but I'm planning on Ironton frame with axle on top of springs and just ply, no other framing, on the trailer frame.
brx017 wrote:QueticoBill wrote:How low do you all go, as in ground clearance? Below the frame? Forgo insulation?
Check out my build, I'm using the Ironton frame. I also put my axle above the springs, but I intend to upgrade to 15" tires. I moved the crossmembers around to suit my needs for a bed that folds into a sofa.
What I did (in CAD) was draw a line from where the tire contacts the ground to the ball of the tongue. Imagine pulling a string from tire to tongue. I assumed this would be theoretically where I would be most likely to hit something and I just stayed behind and above that line. I believe the technical term for this is the approach angle, you can google for a visual. For a rear box in the gallery you do the same, it's called the departure angle.
Since it's a diagonal line, if I stay further back (closer to the axle) it can be deeper. A longer box front to back, or shifted forward would need to be shallower for the same clearance.
Some people might think I'm pushing my luck, but my box is deep. I think it actually hangs a little lower than my axle, but I maintained more ground clearance than my car has. Since I'm not building it for off-road use I feel comfortable doing this. I can't remember exactly, but I'm thinking it's either 8 or 10 inches deep. The 15" tires will help with ground clearance too. I figure the worst case scenario is I knock the box of the bottom of my trailer and lose all its contents going highway speeds in the dark and in the rain.![]()
I'll try to get some pictures and measurements for you so maybe some of this makes a little more sense
Sent from my Nexus 6P using Tapatalk
